Project "Big Country" - Front Bumper Fab - Mill Knob - 11-16-2008 chuzie Wrote:The rebar is a nice touch! Chuzie you mean your Bronco has no rebar ![]() Still looking good Robert:biggthumpup: Project "Big Country" - Front Bumper Fab - blazinchuck - 11-17-2008 Robert, got any pics of the cage arms and the brackets for mounting to the axle. I wanna do the same thing instead off the radius arms I have,Chuck your truck is gonna be baddazzzzzz!!! Project "Big Country" - Front Bumper Fab - nhopman - 11-17-2008 Chuck, Congrats on getting the tons. If you are looking to do the CAGE arms, check on ClassicBroncos (vendor/mass buy section). Lou Levy has a mass buy going on for the arms with the weld on axle attachment. If you are not in a huge hurry to get them, you can probably have them delivered to him and pick them up from the MEB Hooters get together in January to save some shipping. Nick Project "Big Country" - Front Bumper Fab - blazinchuck - 11-17-2008 nhopman Wrote:Chuck, thanks for the heads up Nick!!! will do,Chuck sorry for the jack Robert:toothy12: Project "Big Country" - Front Bumper Fab - SC74 - 11-17-2008 blazinchuck Wrote:thanks for the heads up Nick!!! will do,Chuck No problem Chuck - I'll take some pics this evening when I get home. Project "Big Country" - Front Bumper Fab - SC74 - 11-17-2008 blazinchuck Wrote:Robert, got any pics of the cage arms and the brackets for mounting to the axle. Chuck - Here are a few pics I have from during the build and the last 3 are ones that I took tonight. Mine are only tacked on for now - should have them final welded in the next weekend or two since my next step is finishing the front end. Project "Big Country" - Front Bumper Fab - blazinchuck - 11-17-2008 those look great Robert. Thank you...was it hard to figure out the caster? Project "Big Country" - Front Bumper Fab - SC74 - 11-17-2008 blazinchuck Wrote:those look great Robert. Thank you...was it hard to figure out the caster? It wasn't really hard, just a PITA. We just used the top of the king pin as our reference for caster. That's why it's just tacked for now since we did that so early on and were not positive we had the caster right. I checked it yesterday at it's 5 deg. both sides. I think we'll end up leaving it there and call it good. Project "Big Country" - Front Bumper Fab - SC74 - 11-18-2008 Chuck - You can see how we did it in the install pics. We kind of backed into it by mounting the arms to the frame first and bringing the axle to it. Ratchet straps made it a whole lot easier and helped suck the axle tube up into the bracket real nice. If I remember right, it was harder getting both arms in the same place (or distance from the knuckle) than it was getting the caster set on them. Project "Big Country" - Front Bumper Fab - SC74 - 12-14-2008 I took a several week break from working on the Bronco but got back on it this weekend. I had a near death experience on Friday evening - cutting the tack welds off of the arm brackets with no trac-bar is not a good idea - while I was under the truck it sprung about 1.5 feet to the drivers side and the springs looked like spaghetti noodles. I was cutting the tacks loose so that we could rotate the pinion up some and get a better driveline angle before final welding it. Yesterday we got the cage weld on brackets burned on for good ![]() I have a concern about the trac bar riser - it sits directly under the frame and there's only 6" between the top of riser and bottom of frame. I see that becoming a problem when I stuff the pass front tire ![]() Here are a couple pics. |
