the 77's upgrades - blazinchuck - 03-19-2012 got a few more things done yesterday... changed up the fuel system. added a fuel accumulator,moved the LP pump forward some and added a bigger fuel filter and ditched the small Jegs filter that always needed cleaning. had a lot of movement from the pedal assembly...found the to upward mounting bolts missing. these keep the pedal bracket from flexing the firewall. gotta find a exhaust leak still...its causing a lot of decel popping. things left to do before trip... install air tanks, and hook up OBA. install LED rock lights. modify fan shroud the 77's upgrades - SC74 - 03-19-2012 This warm weather makes it a lot easier to work on the bronco doesn't it... at least it does for me! Curious to see your air tanks installed and see if I can't steal your ideas! the 77's upgrades - blazinchuck - 03-19-2012 i just ordered a autometer fuel pressure gauge/line kit/fittings. gonna mount it in the proform hood! now when this motor falls on its face...ill be able to see if the PSI dropped the 77's upgrades - broncosbybart - 03-19-2012 always some work to do, right? don't forget to add 'paint job' ![]() the 77's upgrades - blazinchuck - 03-26-2012 got a few more things done. the air tanks are in, and all hooked up. now it runs a impact nicely! should air tires up even faster now. also installed some LED rock lights today. so far I like them, wont know how good they really are until it gets darker outside. the 77's upgrades - blazinchuck - 03-26-2012 quick camera pic of rock lights the 77's upgrades - ParadisePWoffrD - 03-27-2012 are those the chinese ones? how many? the 77's upgrades - blazinchuck - 03-27-2012 yeah...u get 20 for $26.01 shipped. i only had 8 left over from upgrading the lights in the camper. i have another 20 lights and magnets coming...but i dont think they will be here by fri. so i slapped 8 under it and very please. they draw .2 amps! camera pic doesnt do justice the 77's upgrades - ParadisePWoffrD - 03-28-2012 I have 20 or so for mine... just wondering how many it took to get that... thanks the 77's upgrades - blazinchuck - 04-11-2012 ok guys...need some help identifying this posi unit. i tore up the upper/lower spider gears the monday after meet/greet. i slipped another carrier with lock-rite in to get me by for a while, but wanna rebuild this soon. heres some pics |
