289 intake - Printable Version
+--- Thread: 289 intake (/thread-1081.html)
Pages: 1 2
289 intake - blazinchuck - 10-30-2008
also, if the intake is low profile...just get a carb spacer with a port on it's side(problem solved) I have on my motor.
289 intake - seanrook - 10-30-2008
There is but doesnt the pcv valve connect there? at least the is whats going on with the stock intake
289 intake - bucketobolts - 10-30-2008
BTW...I used to run a factory cast 4V manifold on my original 302. It worked really well and was low profile.
here is what I have going on, and thanks again guys for your help...
And here is the carb I was hoping to use.
that looks just like the street carb I'm running right now. runs great on the street.
Looks like that will work. Connect the modulator to the angled vacuum port at the front of the carb base plate.
289 intake - seanrook - 10-31-2008
Thanks again guys, will let you know what happens...
