302 EFI conversion - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: 302 EFI conversion (/thread-1335.html) |
302 EFI conversion - chuzie - 03-25-2009 what year was that full size? 302 EFI conversion - blazinchuck - 03-25-2009 its a 87, but the motor is not original...it has a serp. sytem and a nice pump for the hydro assist...id like to use. also, what distributors do 5.0's use...i guess i cant use the non efi D.U.I. thats in the roller motor of the FS bronco. I guess its just a nice HEI dist. guess i need to sell that to...Bighorn...did you ask me about that...lol 302 EFI conversion - blazinchuck - 03-26-2009 Btt, anymore thoughts? 302 EFI conversion - broncomatt - 03-26-2009 What year is your donor mustang? One other code you will have besides speed senser will be evap press senser. Not a big deal, nothing that will efect performance. 302 EFI conversion - blazinchuck - 03-31-2009 ok the EFI motor i got this weekend is a 1990 5.0 HO. from a mustang. I plan to use a RCI 19gal fuel cell in the bed. Any thoughts on running a intank fuel pump?? I'd really prefer not to run all the other pumps/accumalter,etc. I've been looking and dont see a nice drop unit for the RCI, but is there a way to add one?? Thanks,Chuck 302 EFI conversion - broncomatt - 03-31-2009 Probably not, my suggestion is to use a frame mounted pusher pump(at the tank) and then the high psi pump closer to the motor. A great aplication for a high psi pump is the F250 pump from late 80s or early 90s. The pusher(or primmer) pumps I always got an off the shelf unit from napa. To bad you didnt take my book afterall, I had the 90 mustang wiring info right in there. I'll scan everything and get it to you. 302 EFI conversion - johnpaulgolf - 03-31-2009 :popc1: :popc1: :popc1: 302 EFI conversion - blazinchuck - 03-31-2009 haha...pad that junk on your own time...hehe. ok, i have been on the phone with Aeromotive,Jegs, and RCI...im not getting much help on this. Aero suggested i build a duplicate of their steel sump to weld into my Alum tank. Im worried about that. I just find it hard to believe i need to run 2 pumps...what about a holley blue or black...surely that can work by itself??? Robert, what are you using in your efi swap? 302 EFI conversion - broncomatt - 03-31-2009 I remember holly making one that was strong enough to suck out of the tank and creat the correct psi. But it was spendy ($300?). The f250 pump is cheap, a pusher mounted by the tank usualy around $30. 302 EFI conversion - chuzie - 03-31-2009 What does the mustang run? I know they only used one in tank pump right? I will see if I can get some wiring diagrams before this weekend. |
