spools - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: spools (/thread-1515.html) Pages:
spools - bone collector - 05-21-2009 Is there a brand name i should stick with as far as spools, it seems like the detroit is the common as far as lockers spools - 744x4 - 05-21-2009 I just ordered a full steel spool from Randys R&P and dont believe there was a brand name.It was like 125.00 @ the time I got mine several years ago.Dont get a AL one or the one with all the holes drilled in it.Those are for the go fast guys only trying to save weight. spools - broncomatt - 05-21-2009 I had a mini spool in my eb when I got it, Chirped all the time and ate up tires. I swapped to the detroit and have loved it. I do plan on putting the mini spool into the budget bronco, simply because I have it. You can weld the spider gears and make a poor mans spool. But I have broken these and unless you realy cant afford a mini spool I dont recomend it. I also realy dont recomend putting a spool in the front, you will brake shafts or joints for sure. Broncomatt spools - bucketobolts - 05-22-2009 A spool may be a bit harder on stock axles also ![]() spools - johnpaulgolf - 05-22-2009 bucketobolts Wrote:A spool may be a bit harder on stock axles also ummm yeah ... :hysterical: ![]() spools - 744x4 - 05-22-2009 744x4 Wrote:.A full spool needs 31 spline alloy shafts as it is harder on shafts than anything else I thought I covered that in the 101 class.He He:toothy12: |
