Common Driveshaft???????? - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Common Driveshaft???????? (/thread-152.html) Pages:
Common Driveshaft???????? - krazybronco - 10-29-2007 the only down side is the drop plate it can bend due to stress and it could put a hole in the front diff if you flex to hard or jump it Common Driveshaft???????? - BroncJr - 11-12-2007 Well, unfortunately my uncommon driveshaft bit the dust. but fred from Fleet Pride down in Cola, SC helped me out with a brand new one in just a few days. However, as anyone that was at Uwharrie aready knows; i wasn't there and all b/c of a Driveshaft ![]() Common Driveshaft???????? - krazybronco - 11-12-2007 man that sucks wat it from the chip in the driveshaft that made it fail Common Driveshaft???????? - BroncJr - 11-13-2007 naw it wasn't the chip. it was two reasons. the first was shortly after i made the post i started hearing a chirping sound (Cardagan Joint failed), and the other end of the driveshaft was at too much of an angle and i ended up popping ujoint caps left and right. i would put a new joint in and within a couple of miles the grease would liquify and soon after pop-goes-the-weasle. Common Driveshaft???????? - krazybronco - 11-14-2007 dang just get a regular ujoint driveshaft and you should be good becuase i just got one and i have no vibartions what so ever |
