OK, I,m on the fence and need a push - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: OK, I,m on the fence and need a push (/thread-1572.html) |
OK, I,m on the fence and need a push - bucketobolts - 06-13-2009 That is the only draw back to a body lift, the bumper gaps. I prefer a body lift on an EB if I have to work on it. Make dealing with the transmission or transfer case much easier. If you were going to modify it further with aftermarket bumpers that would be no problem. But it is a great looking uncut specimen. I'd pull out the bushings too. OK, I,m on the fence and need a push - 66stocker - 06-13-2009 "I prefer a body lift on an EB if I have to work on it." No doubt. I put my 1" lift on when I had the engine, trans and transfer out. Putting them back in was so mush easier with the body lift. OK, it's done. Got the stock bushings in today and I feel much better, Thanks all. OK, I,m on the fence and need a push - berg bronco - 06-13-2009 I like it A true stocker know OK, I,m on the fence and need a push - sparkchaser - 06-13-2009 It looks realy good. OK, I,m on the fence and need a push - bucketobolts - 06-13-2009 I like it a lot better with out the lift! OK, I,m on the fence and need a push - Mill Knob - 06-13-2009 Well that was fast Bill. I am glad that you went back to the OEM look. I guess you didn't need my help.:popc1: OK, I,m on the fence and need a push - SC74 - 06-13-2009 After seeing the pics w/o the lift I'm glad you got them out! Stock is stock :biggthumpup: OK, I,m on the fence and need a push - 66stocker - 06-13-2009 Thanks for the offer George. Around here with a wife and 2 daughters, my work on the Bronco window is pretty small. I'm getting good at Nascar pit crew style projects. It was'nt too bad ... I had my dog around to cheer me on! OK, I,m on the fence and need a push - Mill Knob - 06-14-2009 I'm getting good at Nascar pit crew style projects. It was'nt too bad ... I had my dog around to cheer me on![/QUOTE] That is good Bill :hysterical::hysterical::hysterical: OK, I,m on the fence and need a push - trkbilder - 06-14-2009 It looks much better without the lift!! :xyxthumbs: |
