the 84 - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: the 84 (/thread-1649.html) |
the 84 - sparkchaser - 07-13-2009 We may look at a couple options.I may call you on it. the 84 - sparkchaser - 07-19-2009 [SIZE="5"]IT'S ALIVE, IT'S ALIVE!!!!!:upup::jump::chili::chili: I got that sombeach runnin.[/SIZE] the 84 - bucketobolts - 07-20-2009 Congrats!!! the 84 - bone collector - 07-20-2009 congrats now a little closer to the trails the 84 - JayT - 07-20-2009 Hot!! How's the engine look now? Still thinking you might finish the 351 for it, or sticking with the 302 it's got right now? the 84 - sparkchaser - 07-20-2009 hopefully I can wait on the 351 until$$$ allows.I'm gonna try to find the vacuum leak and get it runnin a little smoother.At least now I can find other problems, like why high gear don't pull. the 84 - cavscout - 07-31-2009 Hey sparkchaser, I'll never tell if you don't. Your secret is safe with me. the 84 - sparkchaser - 08-09-2009 cavscout Wrote:Hey sparkchaser, I'll never tell if you don't. Your secret is safe with me. :biggthumpup: I spent some time with the 84 today. This morning I poured 1/2 pint of seafoam in the crankcase, started it up and dumped a pint down it's throat. While waiting, I got the rear window down so I can strip the junk out of it, and pulled the doors off.The pass. door only had one hinge on it, so now I can straighten the fenders out and one day put em back on, maybe. After dinner, I finished the bronco enima up.I think I pissed off alot of neighbors........and skeeters:thefinger:Tomorrow I can clean or replace the plugs. the 84 - bone collector - 08-10-2009 ive seen that seafoam in action. Is that a product you like to use the 84 - sparkchaser - 08-15-2009 The transmission is working now, all gears.cratchhe: The motor is runnin better but I need to work on the carb this week. |
