Cronic leak in the right rear axle - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: Cronic leak in the right rear axle (/thread-1740.html) Pages:
Cronic leak in the right rear axle - JayT - 08-03-2009 So that was easy... You can embed directly from youtube now.. Just surround the videoID between the tags "YOUTUBE" or use the YouTube button in the editor window. Cronic leak in the right rear axle - shon - 08-03-2009 sell, you cant sell!!!!!!!!!!!! keep em and love em. never sell. shon Cronic leak in the right rear axle - 73Bronc - 08-04-2009 Testing the new tags for embedding YouTube videos. Thanks JayT :biggthumpup: [YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/u81Po7p1eXE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/u81Po7p1eXE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE] Cronic leak in the right rear axle - 73Bronc - 08-04-2009 Works perfectly Jay T! I will certainly use video more frequently and having this functionality will be sweet! Cronic leak in the right rear axle - 73Bronc - 08-04-2009 Well I finished it up tonight. I ended up removing the vent tube and it was clogged as well. Everything is clear now so I'm hopefully optimistic. Thanks again for the help all! Cronic leak in the right rear axle - JayT - 08-04-2009 Sweet! Glad you found the "smoking gun"! Good luck! |
