Pertronix Ignition Problems. - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Pertronix Ignition Problems. (/thread-1824.html) Pages:
Pertronix Ignition Problems. - SC74 - 09-07-2009 OEM coil will be fine. Is the coil leaking any fluid? Pertronix Ignition Problems. - Mill Knob - 09-07-2009 So I found my promblem. The reason My Pertronix would not work is because I don't have the plastic sleeve that goes over the distributor shalf inside. I called down to Oreilly Auto parts because they carry Pertronix brand and they had a new Pertronix ignition in stock. So me and the wife went and pick it up. While I was there I decided to pick up a new Coil. I ended up getting a Accel coil because they didn't have any in stock. The price of it and a OEM was the same. I could not wait to get home so I could put all the new goodies in my Bronco. As soon as the key turn to start that bad boy came to life. I didn't have to choke it or any thing. So fare so good. Check the pic out. Thanks to all who help. Thanks BILL (66stocker) for posting the pic. That is were I found out that I didn't have all the parts to make it run. Pertronix Ignition Problems. - berg bronco - 09-07-2009 Im glad you got it working Pertronix Ignition Problems. - SC74 - 09-09-2009 Glad you got it solved. |
