Pertronix Ignition Problems.
I am having some problems with my Pertronix Ignition. I placed it in the distributor and hook up the wires to the coil and turn the Key and nothing.:crying:
There is a click coming from the Pertronix Ignition when I turn the key. I have no fire coming from the coil. I pull the plug wire out and layed it on the side of the top but no fire. So what to do?? I took and put the points back in and it started up but it was real rough. So why will it run with points but not with the Pertronix Ignition?
Does any body have ideas?
I put one in years ago and haven't had any problems. Is it grounded properly? Seems it was a simple install. Everything gapped correctly? I'm giving the obvious and probably not much help. Red wire goes to the + coil, black wire to the - coil and the ground wire inside the distributor gets hooked up under the screw that holds the pickup down. All I saw on mine. Had some stuff built up on the contact rotor that slides around the dist shaft. The rotor button thingy and then the dist cap goes on. Didn't change the wires from the cap? coil wire?
Tim
[Image: 2rwp56f.png]
Timstrk Wrote:I put one in years ago and haven't had any problems. Is it grounded properly? Seems it was a simple install. Everything gapped correctly? I'm giving the obvious and probably not much help. Red wire goes to the + coil, black wire to the - coil and the ground wire inside the distributor gets hooked up under the screw that holds the pickup down. All I saw on mine. Had some stuff built up on the contact rotor that slides around the dist shaft. The rotor button thingy and then the dist cap goes on. Didn't change the wires from the cap? coil wire?
Tim
I don't know about the gaping on the Pertronix. I didn't get the little plastic air gapper. I think that is alot of my problem. But I had no fire on the coil? Plus the coil that I have is still the OEM.
Coils can be contankerous - tap it with the handle of a screw driver or even take it out and replace it.
SC74 Wrote:Coils can be contankerous - tap it with the handle of a screw driver or even take it out and replace it.
I am thinking about replacing the coil. Which one should I get from the local part house?
Did I give you a lemon?
berg bronco Wrote:Did I give you a lemon?
I hope not?Confusedcratchhe: I really don't know. I will find out once I put a new coil on it. I plan I buy one tomorrow.
I wounder if a new OEM coil will work? Or do I need to get a hot one.
Mill Knob Wrote:I wounder if a new OEM coil will work? Or do I need to get a hot one.
Im not sure. I would think that a oem one would work.
X2 with Berg. I think an OEM coil will work.
Here's a couple pics of mine so you can see how it goes in.
Set the gap between the pickup ring and the black box at .030.
  Brake problems after the 5.0 swap. BucknEB 10 5,572 10-29-2012, 03:07 PM
  Ford D.U.I. Ignition scbronco 14 11,603 09-06-2012, 06:03 PM
  Soft Top problems!! jollygrngiant 10 5,439 11-22-2011, 12:49 PM
  Ignition switch?? jollygrngiant 10 6,203 09-09-2011, 03:20 PM
Last Post: UTFLIWGYA
  90 Transmission Problems 2000F150SAS 1 2,332 06-21-2011, 10:53 AM
Last Post: 2000F150SAS
  Ignition missing and jumping tach jdowns67 5 3,979 03-23-2011, 01:02 PM
  A good article about ignition timing jdowns67 0 3,139 10-17-2010, 08:52 PM
  brake problems fordfan 4 3,413 09-11-2010, 11:45 PM
Last Post: Ricky B
  Pertronix Solid-State Electronic Ignition jrshepherd 6 7,154 11-08-2009, 11:26 PM
  Ignition Fuse Blown?? SC74 6 4,504 02-12-2009, 11:14 PM
Last Post: Mill Knob
