leaking gas tank - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: leaking gas tank (/thread-2020.html) Pages:
leaking gas tank - JustJeff - 12-30-2009 I punched a small hole in the bottom of a tank once. I also used some JB weld and a sheetmetal screw a little bigger than the hole. It lasted for at least two years. I got rid of the truck. It may still be working???? leaking gas tank - bone collector - 01-06-2010 I still gat a strong smell of gas but the holder is no longer wet and it doesnt leave any wet spots on the ground I did price the tanks and brand new they run from $105-$150 so if all else ill put a new one in need to change out the sending unit anyways it only reads right when it is full or almost empty |
