Another Fine 69 - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: Another Fine 69 (/thread-2198.html) |
Another Fine 69 - firefighter2134 - 05-31-2010 got engine on stand today and got compression test done. got anywhere from 140 to 165 on the cylinders. so i think i might be alright in avoiding a major overhaul. gonna add some modifications to stand to hold radiator and run this piece before dropping it in. Another Fine 69 - firefighter2134 - 06-06-2010 well fired this engine up tonight for a couple min. not long enough to get hot.. gonna attach radiator and get it dialed in then ill be ready for the swap. im stoked!! also im guessing this is an ho engine. according to the firing order. so thats even better! Another Fine 69 - blazinchuck - 06-06-2010 hells YEAH...thats awesome! CANT WAIT Another Fine 69 - Casey835 - 06-11-2010 Yeah youre doing exactly what i want to do. Ive got the 302 that was in my bronco before I tore it apart. It ran very well. I just want to check it out, if its good just put it back in. Of course after I clean it up and make it purty! Good luck with yours! Another Fine 69 - firefighter2134 - 06-14-2010 heres a vid of the engine running. i am gonna fine tune her this evening with vacuum guage and timing light. it is so close the way it sets now but not quite right. easier to tune on the stand. http://www.youtube.com/watch?v=e8NpX-sZxCs Another Fine 69 - medwards01 - 06-14-2010 Man, that's awesome....That baby's purring like a kitten even before you fine tune her!! :xyxthumbs: Another Fine 69 - abunchofidiots - 06-15-2010 Glad to hear your are having good luck with that engine. Another Fine 69 - firefighter2134 - 06-15-2010 found a couple minor things but nothing that wasnt an easy fix Another Fine 69 - firefighter2134 - 06-15-2010 engine is dialed in and ready to go!! hopefully can start pulling 6 banger friday! anyone looking for a 200 6? Another Fine 69 - Casey835 - 06-15-2010 Sounds good to me! |
