hand throttle - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: hand throttle (/thread-228.html) |
hand throttle - partsflyin - 01-22-2008 I did a real simple setup Chuck. ![]() hand throttle - blazinchuck - 01-22-2008 Mine is done and looks like that, however the shifter shaft is about 5/8 OD and the ID of the throttle is 7/8, so right now I have elec. tape to make it fit tighter. Really need a slip bushing. I post some pics later. And the funky rig I made for the carb :lol: hand throttle - partsflyin - 01-22-2008 carb setup ![]() hand throttle - partsflyin - 01-22-2008 blazinchuck Wrote:Mine is done and looks like that, however the shifter shaft is about 5/8 OD and the ID of the throttle is 7/8, so right now I have elec. tape to make it fit tighter. Really need a slip bushing. I post some pics later. And the funky rig I made for the carb :lol: Yeah you can see my ghetto fab shim in the first pic. hand throttle - Ogeechee 4x4 - 09-13-2008 Something told me to search before I posted a thread asking for ideas about a hand throttle... I guess I should go ahead and install one. hand throttle - 744x4 - 09-18-2008 I have a stock hand throttle plate that goes under the gas pedal for a PTO equipped EB if you want some pictures.It is allot easier than the direct to carb route. hand throttle - snipes243 - 09-18-2008 744x4 Wrote:I have a stock hand throttle plate that goes under the gas pedal for a PTO equipped EB if you want some pictures.It is allot easier than the direct to carb route. That would be awesome to see how it's done. hand throttle - blazinchuck - 09-18-2008 :popc1: mines disconnected right now...changing it up. hand throttle - 514f100 - 09-18-2008 used an index shifter ![]() if you need more pic pm me hand throttle - 744x4 - 09-18-2008 Here are a few shots of the stock hand throttle for the EB.It mounts under the gas pedal and actually moves the pedal insted of using a carb linkage. |
