File Line Function
/printthread.php 287 eval
Building a new dash. - Printable Version
+--- Thread: Building a new dash. (/thread-266.html)
Pages: 1 2 3
Building a new dash. - SC74 - 05-04-2008
I haven't forgotten about this thread either - let's see those pics!
Building a new dash. - 744x4 - 05-06-2008
We dont need No Stinking Dash.He He
Building a new dash. - broncomania - 05-29-2008
SC74 Wrote:I haven't forgotten about this thread either - let's see those pics!
Confusedleep:
Building a new dash. - SC74 - 05-29-2008
broncomania Wrote:Confusedleep:
:hysterical::hysterical::hysterical::hysterical::hysterical:
Building a new dash. - blazinchuck - 06-17-2008
BTT...need updates!!!!!
Building a new dash. - hd78bronco - 06-24-2008
blazinchuck Wrote:BTT...need updates!!!!!
Ok Ok, Sorry about the long time with no updates. Here's the rest of the pics. I couldn't put a tube across the front down tubes because they were to far back and it wouldn't line up the way I wanted. So I took some 1/2" plate and welded it to the front of the down tubes and attached the cross tube to that. Then I tried to use some sheet metal I had laying around for the dash panel.
Building a new dash. - johnpaulgolf - 06-24-2008
looking good keep us updated!!!
I screwed up the sheet metal so I went and picked up a piece of 1/8" aluminum plate. It worked and looks alot better. I cut out the holes for the gauges and for the switch panel. I also moved the fuse box up to the dash for easier access. Then I wired everything up before installing the dash.
Here's the finished pics.
Building a new dash. - SC74 - 06-24-2008
Very nice! I like the aluminum look to - looks like you did some custom etching on it!
