My 76 repairs. - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: My 76 repairs. (/thread-2730.html) |
My 76 repairs. - JayT - 03-28-2011 Nicely done, Chuck! That's the kind of man he is. :biggthumpup: My 76 repairs. - SC74 - 03-28-2011 Grand Poobah strikes again! Glad you got it back together and running well. If the flex plate were the wrong weight I think it would be an unbearable shake. How bad does it vibrate? You bringing it to Charlotte? My 76 repairs. - BucknEB - 03-28-2011 It's has a good shake to it at low rpms and somewhat smoothes out around 2.5-3rpms. I don't have a tach installed on it so I'm just guessing. A tach is on the list. I will not be driving it up to Charlotte ![]() My 76 repairs. - jollygrngiant - 03-28-2011 So how much did he charge you for the work he did and the labor and all? My 76 repairs. - blazinchuck - 03-28-2011 jollygrngiant Wrote:So how much did he charge you for the work he did and the labor and all? $30/hour...for full members cmon:beer: find that anywhere else in town:popc1: thanks guys! i couldnt let the man down:biggthumpup: My 76 repairs. - BucknEB - 03-29-2011 jollygrngiant Wrote:So how much did he charge you for the work he did and the labor and all? Imagine what it would cost for a shop to tear down the whole front of the engine, pull the radiator, replace a harmonic balancer, timing cover seal, water pump, all the gaskets(timing cover, fuel pump, water pump). and then drop the oil pan, fix/reseat the oil pump rod from the distributor, replace the oil pan gasket. Fix/replace my Shotty intaket manifold gaskets job that were leaking, and then adjust the carb and timing. Not to mention pressure wash the whole under carriage. Just take a guess at what alll that would cost at your local service shop. Needless to say Chuck's price was well below that!:jump: Thanks Chuck! You are the man!:xyxthumbs: My 76 repairs. - ncsubronc - 04-01-2011 saw you driving by yesterday as i was putting some diesel in the truck at the kangaroo on the corner of maybank and river rd. top off, cold, nasty rain and all. :notworthy: My 76 repairs. - BucknEB - 04-01-2011 Yep. the afternoon commute home. I haven't gotten around to installing the soft top I picked up from Crawdad. It wasn't that cold in the mid 50's, and the rain was more like a drizzel. What can I say, I love driving my Bronco rain or shine. ![]() My 76 repairs. - Crawdad - 04-01-2011 DougV76EB Wrote:Yep. the afternoon commute home. I haven't gotten around to installing the soft top I picked up from Crawdad. It wasn't that cold in the mid 50's, and the rain was more like a drizzel. What can I say, I love driving my Bronco rain or shine. I found the installation manual for that soft top if you need it. I can mail it or pdf it to you. My 76 repairs. - BucknEB - 04-04-2011 Crawdad Wrote:I found the installation manual for that soft top if you need it. I can mail it or pdf it to you. Thanks, I'll PM you. |
