File Line Function
/printthread.php 287 eval
Specs for 351W motor mount bolts? - Printable Version
+--- Thread: Specs for 351W motor mount bolts? (/thread-2907.html)
Pages: 1 2
Specs for 351W motor mount bolts? - 73Bronc - 09-26-2011
Here's a pic of the front side of the mount. I can move it left a right but it also needs to move forward a bit. I jacked the engine slightly from the bell housing joint but still couldn't get the mount to move forward enough to line up due to the frame bolt being in place. Would a punch damage the threads inside the motor?
[Image: Untitled00018-30.jpg]
Specs for 351W motor mount bolts? - 73Bronc - 09-27-2011
It took some work but I was able to get it mounted down tonight. :rockon:
