Specs for 351W motor mount bolts?
Does anyone know the specs for the 351W motor mount bolts that go up into the block? During my work to replace the oil pump, I noticed two were loose and two were gone. I think I put the wrong ones back in when I pulled the motor.
they should be no less than grade 5. Look for three dashes on the bolt head. Use lock washers too.
i think they are 7/16th coarse thread...or 1/2-13
they are 7/16 coarse thread. probably 3/4" or 1" long.
I'm able to find 7/16-14 at Lowe's but no 7/16-13. I also tried Carquest locally but they didn't have the 7/16-13 either.
Try fastenal... and bring an old one with ya, if you can, to be sure they match... Or JBG has em for 5 bucks or so...
7/16-14 is coarse thread. 13 TPI is for 1/2" bolts. Lowe's will have what you need. Isn't it fun to have to run back and forth a few times???
There is no such thing as a 7/16-13.
Yep, went back to Lowe's and got the 7/16-14. Of course now the motor is not lining up with the mount holes :crying:. It's about 1/16th off and I can't get the bolts in. I guess it moved when my Dad drove it down the street. :banghead: So now I guess I have to find a way to move the motor back. I guess the only way it to loosen the tranny bolts and get a jack?
I think I'll loosen the mounts and see if I can move them enough to line everything up. Nothing a little hammering can't fix right? :beer:
you are on the right track. loosen up the engine mounts from the frame (the big 3/4" nut) and use a punch through the bolt holes to try and line everything back up. you shouldn't have to loosen the trans mounts, unless the engine has shifted a lot.
  Which Motor Should I Use? obxbronco 7 4,463 02-24-2016, 10:01 PM
Last Post: obxbronco
  motor help!!!!! broncatron 6 6,284 07-09-2013, 10:03 PM
Last Post: broncatron
  motor issues please help!! bigredbronco 9 5,186 12-22-2012, 11:30 AM
Last Post: bigredbronco
  1991 351W EFI Question Crawdad 4 3,905 03-27-2012, 09:05 AM
  Blown Motor. NateMob 22 11,831 11-02-2011, 09:26 PM
Last Post: NateMob
  spare tire mount snipes243 12 8,424 11-28-2010, 06:05 PM
  fender bolts Casey835 3 2,493 07-17-2010, 10:25 PM
Last Post: Casey835
  Swapped the motor in my Centurion and added a turbo! smooth 4 3,291 12-11-2009, 01:43 PM
  Thinking about swapping my 351W for a 302 cavscout 8 4,333 10-22-2009, 08:02 AM
  Need Advice on 351W Headers 73Bronc 9 5,994 10-15-2009, 12:04 PM
Last Post: wormhole
