Replacing a lub bolt stud on rotor - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Replacing a lub bolt stud on rotor (/thread-3011.html) Pages:
Replacing a lub bolt stud on rotor - broncosbybart - 12-08-2011 That is some awfully high torque for the locking nut. You'll be hard pressed to get that without the tool wanting to walk off of the locking nut. I usually tighten them 'lug nut' tight. You will be able to repack the outer bearing but not the inner. Clean the bearing really good to check for pitting or scoring. Replacing a lub bolt stud on rotor - blazinchuck - 12-08-2011 Ya forgot the most important step JayT!! Step 1 PUT CUTE LATEX GLOVES ON,THEN MECHANIC'S GLOVES LMAO!!!! Replacing a lub bolt stud on rotor - broncosbybart - 12-09-2011 Nah, if i'm just working with grease, it is Nitrile (not Latex). C'mon! Maybe some day you guys will get it right.. :biggthumpup: Replacing a lub bolt stud on rotor - Casey835 - 12-10-2011 hey crawdad that torque spec on the outer spindle nut sounds a lil high Replacing a lub bolt stud on rotor - blazinchuck - 12-10-2011 ive seen 200lb tq on the outer before, not uncommon |
