EFI wiring harnesses - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: EFI wiring harnesses (/thread-3074.html) Pages:
EFI wiring harnesses - broncosbybart - 02-16-2012 you ought to just run a big ole' carb on the half cab, chuck... hadn't seen the kolibar site. looks like a great idea. i don't have any issues with reusing a stock harness. it takes a good long while before wiring goes bad. EFI wiring harnesses - SC74 - 02-16-2012 I have not seen the re-build option before, but then again I've never had a full harness to start with. I will need one in the next year or so to convert Jessica's bronco to EFI but I have some time to wait and see if RJM rebounds. EFI wiring harnesses - BucknEB - 02-16-2012 I just got off the phone with Rick at Kolibar. I had a few questions for him. He said that the he tests everything and he assured me that it will work. he also said that "it will not look as good as a RJM harness but if your not building a show truck why bother". I have to agree. My Bronco is not a show truck and never will be. His price is $280 for the service and the turn around time is 2 weeks. I'm going home today and packaging it up. I may even send it express. ![]() EFI wiring harnesses - broncosbybart - 02-17-2012 just send it in a flat rate USPS priority box. a medium box is like $11 and a large is like $15. it'd get there in 3 days or less. EFI wiring harnesses - BucknEB - 02-17-2012 broncosbybart Wrote:just send it in a flat rate USPS priority box. a medium box is like $11 and a large is like $15. it'd get there in 3 days or less. Shipped it out! That's exactly what I did. "If it fits, it ships":xyxthumbs: EFI wiring harnesses - nhopman - 02-17-2012 blazinchuck Wrote:???explain I have re-worked a few of the original Mustang harnesses including the one for Charles. I Eliminated unnecessary wires and added the extra relays and plugs like RJM does. And re-wrapped the whole harness to fit into an EB. It is pretty time consuming and tedious. I suppose doing them on a regular basis it would get easier, but I probably don't have the paitents to do it day in day out, so I don't see starting a wiring business. The wires used in OEM harnesses is top quality stuff. I wouldn't hesitate having an original re-worked. You can do it yourself for about $50-60 for the new wire wrap, relays and some weather pack plugs. Ryan used to sell a kit (and may still) with all the stuff you need to re-work one. Just get a couple of good wiring diagrams figure out the layout and take your time and it's not too bad. The hardest part is cutting the first wire. Nick EFI wiring harnesses - broncomatt - 07-04-2012 I had been asked about how to wire up ac with the stock 5.0 and how to increse rpm for use with a winch or welding. I have included some diagrams that show the factory ecm connector and what they go to. Pin 10 is for the ac, it should be run threw a switch and a relay. The pressure swich could be omited but I wouldent recomend it. Pin 21 is for idle speed control, if it is put thew a switch to pin 37 it could be toggled on to connect the circuit, this would increase the rpm as if the ps rack were at full lock and require a boost in rpm. This would utilze the iacv. I have included the diagrams for the mustang and the crown vic, I do have other diagrams depending on what people need. Hope this helps. |
