Steering box help - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Steering box help (/thread-3791.html) |
Steering box help - nhopman - 07-07-2015 I always hate when I can't get a problem to repeat itself. I believe this is a popular option for a conversion setup if you can't find a stock 4-turn replacement. http://www.wcb4x4.com/tech/diyrockcrawler.shtml Steering box help - chuzie - 07-07-2015 Do you have any vertical play in your pitman arm? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! Steering box help - broncosbybart - 07-07-2015 Maybe it's the nut behind the wheel?? Steering box help - nhopman - 07-07-2015 broncosbybart Wrote:Maybe it's the nut behind the wheel?? Did you mean Clay, or the actual nut at the top of the steering column directly underneath the steering wheel? One way is proper Tech, the other is funay. Steering box help - broncosbybart - 07-07-2015 Is anything I do 'proper tech'? That is a diagnosis my dad gave to me years ago. Just passing his wisdom along. Steering box help - chuzie - 07-07-2015 Love it! Lmao! I thought same thing Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! Steering box help - snipes243 - 07-07-2015 The nut got the problem to reoccur. No play in the box I'm gonna take it the box off. And start looking for replacements. Steering box help - Crawdad - 07-07-2015 For what you do I suggest the 4x4x2 conversion. A couple of people sell them on CB. West Coast I believe sells them. I believe it's a stronger box than a factory four or six turn box. Don't know if ur interested in going hydro. I have an old 70s Ford f100 2wd PS box. It's the long version. If interested let me know, will separate cheap. Steering box help - snipes243 - 07-07-2015 Well got it out and there a little play in both the input and output shaft. Going to call west Texas offroad see what they say ![]() Sent from my iPhone using Tapatalk Steering box help - snipes243 - 07-08-2015 They are thinking its either a crush ball or the center pin is broke. |
