Steering box help
So I had some steering problems at Harlan this past weekend. I was coming down the mountain and made a hard passenger turn to all the way lock. At that point the steering wheel would just free spin, like it wasn't attached. After I used the winch to straighten the wheels, I wiggled the steering wheel back and forth. And the steering came back. Could a stripped tooth in the steering box do this? I haven't tried to go to full lock yet. Any ideas?
If you are back home by now try it again in the drive way. If it does it again, pull the sector shaft out and see what you find.
Might be time for some fancy parts and ram assist.
I know where there is a PSC full hydro setup. Smile
broncosbybart Wrote:I know where there is a PSC full hydro setup. Smile
Where??
'73 Bronco - trail modified
Yes, do tell.
On the floor in my shop...
Sorry for the hijack. Let us know what you find Clay
Screw clay. Whatcha want for the setup? :-)
ive had a steering u joint slide up or down...causing the shaft to not engage the ujoint before...but once it happens, it wont fix itself....yours sounds weird
Well it gets weirder, I pulled it in the garage turned the wheel from lock to lock and no issues. I had it in 2wd when It locked up it happened in 4low do you think that matters any?
It might be right at the limit at full lock, try lifting the wheels off the ground and go to full lock, then kick the tire to see if you can get it to jump the gear. Might be time to change to a 4 turn box.
Nick
nhopman Wrote:It might be right at the limit at full lock, try lifting the wheels off the ground and go to full lock, then kick the tire to see if you can get it to jump the gear. Might be time to change to a 4 turn box.
Nick
I will give that a try nick, and see what happens. I have been looking for a 4 turn box but have found any, if you know where one is I'm all ears.
  Heim Steering wepuckett 20 9,447 08-28-2015, 03:18 PM
  What type Power Steering Cooler are you all using? Broncitis 7 4,142 07-16-2015, 01:32 AM
  Steering shaft Extension Question??? Broncitis 4 4,656 04-17-2015, 02:27 PM
  Quick disconnect steering wheel snipes243 4 5,431 08-21-2012, 06:50 PM
  Power Steering issues Crawdad 31 13,326 07-28-2011, 09:29 PM
  Heater box : Name that part! chuzie 8 4,494 12-29-2010, 11:26 PM
  Home made heavy duty steering Timstrk 4 4,184 11-25-2010, 10:47 AM
  power steering pumps snipes243 9 7,889 11-15-2010, 05:17 PM
Last Post: nhopman
  steering column bluebooger 0 2,336 01-19-2010, 11:57 PM
Last Post: bluebooger
  HELP INSTALL POWER STEERING PBONE2000 3 2,812 12-11-2009, 01:08 PM
