Gear reduction starters - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: Gear reduction starters (/thread-3936.html) Pages:
Gear reduction starters - snipes243 - 07-16-2016 ![]() ![]() Here is the pictures Sent from my iPhone using Tapatalk Gear reduction starters - chuzie - 07-16-2016 Snout height shouldn't matter unless it is so tall that the pawl doesn't engage the flywheel. Have you tried jumping the terminals with it installed? Could be mechanical or electrical. Just because it clicks doesn't mean the pawl has even extended. My first stop would be to reinstall and do a voltage drop test or jump the terminals and supply voltage directly. Gear reduction starters - snipes243 - 07-17-2016 After an lot checking and reinstalling I got it to work. I removed the little spade tab on the solinode which apparent I was suppose to. I think that was probably my issue Sent from my iPhone using Tapatalk |
