Gear reduction starters
I have been looking through old threads but cant find the original thread. But I'm looking at converting to the new style starters. What is everyone running.
when I click on my saved link it says part not found, but I believe this is the same one I have been using.
http://www.dbelectrical.com/p-1095-ford-...89-04.aspx
Nick
'73 Bronco - trail modified
I went with DB on several rigs. Bought both the auto and manual transmission types with good luck. The auto trans starter looks identical to a late model explorer starter.
i always use the explorer starter or the mid 90's f150- for the manual starters
nhopman Wrote:when I click on my saved link it says part not found, but I believe this is the same one I have been using.
Nick
I like the price, Have you had any issues with it?
No major problems.
I did some more poking around their site and here is another one that may work for you as well.
http://www.dbelectrical.com/p-9936-ford-...d0001.aspx
nhopman Wrote:No major problems.
I think I will give that a try.
DB's one of the best for a good product and they have a great selection. I've still got my first starter from them, still kicking ass!
I ended up ordering the manual version on this one. We will see how it looks soon.
So I got my starter today got it hooked up and it won't start just clicks so I check my connections everything appears ok. I took it back out and bench tested everything ok. I noticed the snout was of. Does this look off to you
  66-77 steering gear box rtj731 1 1,936 09-24-2015, 03:09 PM
  New Low Gear option! blazinchuck 0 1,518 08-06-2010, 02:04 PM
