BII 302 Swap - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: BII 302 Swap (/thread-550.html) |
BII 302 Swap - bucketobolts - 04-12-2008 66bronco has a tubing bender. I'm sure we can fixer' up! BII 302 Swap - Wrenchbender - 04-12-2008 I'm sure you can and If i start mine first I'll share the info as I go. That is if'n I ever figure the thumbnail thang out. ![]() ![]() BII 302 Swap - Wrenchbender - 04-12-2008 BTW where you fellers located? BII 302 Swap - bucketobolts - 04-12-2008 In the middle of NC. BII 302 Swap - Wrenchbender - 04-12-2008 Cool now I see it. BII 302 Swap - trkbilder - 04-13-2008 :biggthumpup:A 302 in a B2, I'm all ears!!:notworthy: BII 302 Swap - Wrenchbender - 04-14-2008 trkbilder Wrote::biggthumpup:A 302 in a B2, I'm all ears!!:notworthy: :rubeyes:But it wont be stock:hysterical: juzz ribb'n ya trkbilder, but there are a few around with 302's. BII 302 Swap - trkbilder - 04-14-2008 When I finally wear my 2.9 out I'm wanting to do a 4.0 swap, so the 302 swap is something I might be interested in. Gas has got to come down first, mine will be a daily driver! ![]() BII 302 Swap - chuzie - 04-14-2008 Just get one of those computers that shut down 4 of they cylinders when not needed. BII 302 Swap - Wrenchbender - 04-14-2008 trkbilder Wrote:When I finally wear my 2.9 out I'm wanting to do a 4.0 swap, so the 302 swap is something I might be interested in. Gas has got to come down first, mine will be a daily driver! I hear ya on the gas prices, and there are a lot of guys that have done the 302 swap I hear its a lot easier if ya have a body lift. But it will clear without the BL its just a bit tight in the firewall area. |
