BII 302 Swap
Hi ya'll, it has been awhile seen i was last on, but nothing much has changed. One thing that is on the drawing table is a 302 swap. i was GIVEN a 302 for free. i am in the process of rebuilding it because after closer inspection i found a busted piston. my question is if there is any bII running a 302 here that may be able to give me some pointers as to what parts fit/interchange. i have done some research and have concluded that the block is from 1972 and was originally in a fairlane/Torino( was orig. told from 76-78 f100). i am looking to get the most low-end torque that i can without sacrificing speed (80mph tops).
like always ANY and ALL help is greatly accepted and appriated.
thanks
chris
p.s. looking for a BII rim (15x10)
Taking the mudguppy one rut at a time.
man, I cant wait for this to get started...I been wanting to swap a 302 in my ole ford ranger(1990)...really wanted to set it up for scca track stuff.(never got there though)
i am hoping to do a thorough write up if i can get some help when the time comes. i have to replace one piston, so i am going to rebuild it and add the neccessary parts to achieve my goal.
I may have a few 302 parts laying around, headers,other stuff..let me now when ya get close what we can do to help.Chuck
If you have a big budget stroke it to 331-347 and run a good set of AFR heads.
If your looking for bang for the buck I would bore it .030" and use a set of Speed Pro flat tops. Stock cast heads will make good power, but if you get into swapping larger valves and mild porting, it would be just as easy to go with a set of after market heads. Cam choice is also pretty important. Your block is designed for flat tappet hydraulic cams. If you keep the duration around 220* or less and the lift less than .550" it should be very streetable and easy on the valve train. Comp Cams makes several different grinds, FRPP and Summit brands are several that I've used and been pleased with.
Get an idea of what you want and I can run the #'s through my Desktop Dyno to give you an idea of your final product.
I've heard that the frame will be your weak link with the 302. I would probly do a little boxing & fish plating if I were doing this.
302 in a b2 = awesome.
Wrenchbender Wrote:I've heard that the frame will be your weak link with the 302. I would probly do a little boxing & fish plating if I were doing this.
The 302 is no real torque monster. Where is the frame weak?
bucketobolts Wrote:The 302 is no real torque monster. Where is the frame weak?
If you're not going extreme on hp or over working the BII on the rocks it may work fine for ya. But there have been a few with this swap that have had real issues. One that comes to mind right off is a guy (Mekcanix) on another site. His frame is begining to look like a pretzel and has spreaded 2" to the point its tearing the floor pan. But like I said He has a little extra hp and is an extreme off roader. If I remember correctly the problem area is between the firewall and the front seat as there is no real bracing there. If one was to install a frame brace in that area IMHO it would greatly reduce this problem.
See I myself have been thinking about this same swap and wieghing the pros and cons. So don't think I'm trying to discourage you in any way, I just wanted warn ya about this weak link.
Oh and another thing I forgot to mention is that hav'n a body lift will also have an effect on the frame in this area. The body kinda acts like a stiffener to keep the frame rails from spreading on the top side, therefore IMO with a body lift the link would be longer between the frame and brace(body) giving it more chance to spread. I don't think it would ever cause any problems with the 2.9 but with 5.0 its possible.
The upside of hav'n a bodylift is then you would have room to fab a brace from rail to rail to stop the problem before it starts. As stated above this is just my opinion I don't have any hard facts to prove or disprove it other than the one I mentioned in the earlier post. BTW I'm not claiming to be be a BII GURU by any means if the truth be known I'm far from it.
  Need input on my NV4500 swap!! knoxville714 12 9,654 06-20-2016, 09:59 PM
  Manual to Auto swap and Auto to manual swap wepuckett 1 2,900 07-24-2014, 03:26 PM
  Brake problems after the 5.0 swap. BucknEB 10 5,586 10-29-2012, 03:07 PM
  who's running 302-4r70w-zf-d20 j shift-twin sticks? chuzie 2 2,339 12-11-2011, 10:14 PM
  AOD SWAP TO A C6 markharrell 3 3,213 09-30-2011, 09:18 AM
  1973 Bronco 302 mcgyver 6 4,187 01-30-2011, 10:58 PM
  water pump v8 302 torque spec jrshepherd 5 5,154 11-13-2010, 10:45 PM
Last Post: Casey835
  Carburetor and intake manifold 1974-302-auto jrshepherd 6 5,179 03-04-2010, 02:08 PM
  saginaw swap chulo2004 6 7,134 02-07-2010, 10:10 AM
Last Post: DeTowman
  Torque Spec. Spark Plugs- 1974 302 v8 jrshepherd 4 3,816 01-24-2010, 12:47 PM
