'93 sploder rpm problem look what wifey is getting - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: '93 sploder rpm problem look what wifey is getting (/thread-552.html) Pages:
'93 sploder rpm problem look what wifey is getting - chuzie - 04-10-2008 Don't forget the other items that could be at fault are... O2 sensors Coolant temp sensor Bad ignition Bad fuel Poor ECM ground Birds nest or the like in the exhaust Bad VSS sensor. Ok. Now I think that is everything. '93 sploder rpm problem look what wifey is getting - Mill Knob - 04-11-2008 I have a 93 Sploder and it was not wanting to idle right ![]() George '93 sploder rpm problem look what wifey is getting - 744x4 - 04-11-2008 The problem I had on My 94 was a clogged cat but a big prybar cleared the innards right out and it actually has a throaty note to it now.I just paid $1865.00 in August for a rebuild on the tranny and the guy had to go through 3 cores just to get a good case to rebuild.It was my Daughters first day of College so it was a expensive day ![]() '93 sploder rpm problem look what wifey is getting - ONEWYR - 04-11-2008 I am gonna do a manual tranny swap on it '93 sploder rpm problem look what wifey is getting - 744x4 - 04-11-2008 Probally allot cheaper.Mine wont rev up either unless it is in gear and you can hear it bounce off the rev limiter and drop power.Maybee it is to keep you from doing N drops in it and shattering the Glass tranny |
