FRAME PRIMER/PAINT - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: FRAME PRIMER/PAINT (/thread-809.html) Pages:
FRAME PRIMER/PAINT - Bighorn - 06-30-2008 Don't forget some of your small parts that will make a big difference when you reassemble. Things like the Rear shackles, upper and lower spring cups, spring retainers, track bar, steering links, etc You can always go back but getting it done all at once is helpful if you want it all to match up and you're not waiting on the poweder coater to finish small batches. FRAME PRIMER/PAINT - DUCKWORTH71/76 - 06-30-2008 Thanks bud.....I appreciate the help......I'll be dropping off the rear spring shackles and the spring retainers tomorrow..... Hank |
