Need full width info. - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Need full width info. (/thread-934.html) |
Need full width info. - Ogeechee 4x4 - 08-11-2008 blazinchuck Wrote:if I'm not mistaken, if it's a D44 8 lug, just get new hub/rotor for a D44 5 lug. They should be interchangeable. I've got the parts to swap from 5 lug to 8 from a '78/9 F250. The knuckles are the same, but spindle, caliper bracket, caliper, hub, rotor are different... Need full width info. - broncomania - 08-11-2008 blazinchuck Wrote:if I'm not mistaken, if it's a D44 8 lug, just get new hub/rotor for a D44 5 lug. They should be interchangeable.he needs caliper brackets,hubs,rotors,calipers,spindle,stub shaft. edit:if i remember correctly the stub shaft is just a hair longer. Need full width info. - Ogeechee 4x4 - 08-11-2008 broncomania Wrote:edit:if i remember correctly the stub shaft is just a hair longer. Is it? 79f150 & I looked into that and we couldn't find a straight answer... Need full width info. - Traveler - 08-12-2008 If we bought a F250 D44 we would just stay with the 8 bolt stuff, rims are cheap and easy. So what years F150 had the welded on Wedges? 1977? I found an excellent donor for $500 I could use tires, wheels, body parts, interior it all looks good yet. Or a '76? One here with not as many good parts for $400. Or is that still too new? Thanks again guys. Need full width info. - blazinchuck - 08-12-2008 the 76 will have drums and a 77 will have disc. the 78 and up will have cast wedges. I think the 77 will have the thickest axle tubes also..mine are 1/2 wall thickness. 76-77 weld on wedges,HTH,Chuck Need full width info. - johnpaulgolf - 08-12-2008 johnpaulgolf Wrote:I would'nt know nothing about no fullwidths...:angry: :angry: :finger: :puke: Need full width info. - blazinchuck - 08-12-2008 johnpaulgolf Wrote::angry: :finger: :puke: would you quit your crying:hysterical::thefinger: Need full width info. - broncomania - 08-12-2008 blazinchuck Wrote:the 76 will have drums and a 77 will have disc. the 78 and up will have cast wedges. I think the 77 will have the thickest axle tubes also..mine are 1/2 wall thickness. 76-77 weld on wedges,HTH,Chuck76 do have disc brakes.maybe not all of them but the ones ive stripped have had disc. 76/77 both are weld on c wedges. hp44 67" wms to wms thick axle tube. note: the only reason for the thicker axle tube was because the c wedges were being welded on. the heat from being welded required thicker steel tube. Need full width info. - broncomania - 08-12-2008 blazinchuck Wrote:would you quit your crying:hysterical::thefinger::hysterical::hysterical: Need full width info. - broncomania - 08-12-2008 Ogeechee 4x4 Wrote:Is it? 79f150 & I looked into that and we couldn't find a straight answer...as far as i know, they are. |
