Chuzie's monster transformation - Printable Version
+---- Thread: Chuzie's monster transformation (/thread-2310.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
Chuzie's monster transformation - blazinchuck - 03-11-2013
chuzie Wrote:I am just looking forward to breaking something major in April!
THE HELL YOU ARE! every time you do...im right there with yo azz!...no thanks bro
Chuzie's monster transformation - chuzie - 03-11-2013
Must be all that "over-engineering!"
Hey! You've had a hand in building this chit half-a$$ed just as much as I do, so you are equally liable to suffer the consequences when it falls apart at the most inopportune times / locations.
it looked kinda happy in the lot today...peeking over the wall lol
i think its diggin its new owner...just sayn
[Image: 2013-03-11_08-09-46_156_zpsa4805f39.jpg]
Chuzie's monster transformation - broncomatt - 03-12-2013
ROFL!!, glad to see he finaly has something worth driving! When you ever going to get around to putting a rear disk kit like I built!! You saw how mine works, Realy glad to see its coming together.
Chuzie's monster transformation - chuzie - 03-12-2013
My rear drums are shot, cylinders completely dead and shoes soaked in oil; basically zero rear brakes. Trust me, rear discs are on the list. My goal is have it done by end of June when I am slated to return to FL with Bronco.
Chuzie's monster transformation - Crawdad - 03-12-2013
Here is that business card I said I would get you.
Chuzie's monster transformation - chuzie - 05-16-2013
Update from M+G / URE.
Changed out my LP pump again and upgraded to a Carter P4070. The return flow is significantly greater than any of the other pumps I have run in the past. Once my fuel level gets low enough (1/4 tank) I will test and see if I have any priming problems. Still plan to do new pickups in the tank but I think my crappy LP pumps have been a contributing factor to me having supply issues. The pump was $90. I bought 2 so I always have a spare!
Also found my 4x4x2 PS box was crushing my frame so I installed BC's frame reinforcement kit.
Finally installed my LED rock lights.
Installed my ram assist today.
[Image: 4y5u3e2u.jpg]
Explorer rear discs are going in next week along with a mechanical line lock and my 65mm TB upgrade.
TO DO list update:
*** 70mm MAF *** COMPLETE ***
*** New oil dip stick *** COMPLETE ***
*** Redneck ram *** COMPLETE ***
*** Rock lights *** COMPLETE ***
*** RTI ramp *** COMPLETE ***
Chuzie's monster transformation - broncosbybart - 05-18-2013
Nice! That's a good bit of work chuck did for ya Smile
Sounds like you are getting it done!
Chuzie's monster transformation - chuzie - 09-27-2013
Just cleaning up some items on the list...
*** 65mm TB *** COMPLETE ***
*** Install TB cooling lines *** NOT NEEDED ***
*** Rear brake cylinders *** COMPLETE *** (installed rear discs instead)
*** Repair turn signal switch *** COMPLETE ***
*** Steering stabilizer *** NOT NEEDED *** (installed ram assist)
*** Sway bar *** NOT NEEDED *** (Used nitrogen shocks instead)
