the 77's upgrades - broncomatt - 02-17-2015 well hell, I thought you may have traded yours in for a KIA. Glad hear your so happy with the build you have created. I like the Power Lok, but for a true locker what about the Detroit or electric lockers? You ever going to get around to painting it or are you really in love with the primer? the 77's upgrades - blazinchuck - 04-27-2015 Woohoo!!! Tom woods rear shaft showed up today!! Now I'm ready!! Sent from my HTC6500LVW using Tapatalk 2 the 77's upgrades - lilpanther - 04-27-2015 Now you should really be ready for some wheeling. the 77's upgrades - blazinchuck - 04-27-2015 hells yeah hot damn!! i was getting a bad vibration every time i let off the gas or between shifting gears. well back when i moved the axle back 1.5", my old shaft wouldnt work. so i traded shafts with Ryan and is was less than desirable lol...pretty sloppy. i was hoping the new vibration was just the shaft. it would get bad up around 70mph. so today, i was very pleased with the TW shaft and cruising 80mph is no problem!!! in fact, the bronco loved it...i tried to get some pics of the dakota digital sitting at 80, but that proved testy lol the 77's upgrades - lilpanther - 04-29-2015 Glad to hear that got your problems fixed. It'll be nice not to have it vibrating all the way to Tellico. the 77's upgrades - blazinchuck - 02-24-2016 guess its time to bring this up to date. i decided to throw down on it and get the painting done finally. will im at it, i will be cleaning up all the wiring behind the dash, upgrading the switch panel. not sure there is time for much else. i removed the front gas door, fitted new metal in that hole, got some better doors from scbronco which had a long dent in the bottom. so i bought a stud gun from HF which worked awesome! fixed the dent i caused at tellico and a bunch of they other issues i had with the body. heres some pics so far. going with a honda neutron blue pearl B537M. the 77's upgrades - blazinchuck - 02-24-2016 i also bought some stainless lift off hinges, i will be installing. need a bunch of other hardware too...and tail lights. the 77's upgrades - blazinchuck - 02-24-2016 only had a quart of Limco 800K(2k surface primer) so i will need more...that only did a good coat the 77's upgrades - blazinchuck - 02-24-2016 as it sits... the 77's upgrades - scbronco - 02-24-2016 Looks good! Glad the doors worked out for u!!! |
