Finally on all 4 wheels - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: Finally on all 4 wheels (/thread-1290.html) |
Finally on all 4 wheels - 744x4 - 04-05-2009 Fired up the Tire Groover today and cut one of the swampers up.One pic shows how much is removed with a basic groove job.The other picture is more of a question as do you think I should cut anymore across the tread where the silver lines are drawn.I dont want them to start chunkin tread and I think it will be too much but I have witnessed some seriously grooved swampers before that held up on a buggy. I also finished the Tubular radius arms and made the trac bar adjustable to compensate for these small lift coils.Now to get some more coils and call it good in ft for now until I make the dom steering rods. Finally on all 4 wheels - SC74 - 04-05-2009 Dang... that cut smooth. How long did one tire take? Finally on all 4 wheels - broncomania - 04-05-2009 grooving tires is a pita on your arm. looks good, works good but time consuming. Finally on all 4 wheels - 744x4 - 04-05-2009 About 30 min with the break on the last outside pass as my arms were Popeyed.I unplugged the groover and let it rest before I did the last pass as it was hot as hell by then. I think I am going to just continue my pattern and not cut anymore extra out. Finally on all 4 wheels - SC74 - 04-05-2009 744x4 Wrote:About 30 min with the break on the last outside pass as my arms were Popeyed.I unplugged the groover and let it rest before I did the last pass as it was hot as hell by then. I think I am going to just continue my pattern and not cut anymore extra out. :hysterical: You will be wearing you tennis elbow support again :hysterical: Finally on all 4 wheels - 744x4 - 04-05-2009 Emileigh calls it my Old Man Band.He He Finally on all 4 wheels - broncomania - 04-05-2009 i think you will be satisfied with how they are cut now. Finally on all 4 wheels - trkbilder - 04-05-2009 Man, those look good!! :xyxthumbs: Finally on all 4 wheels - 744x4 - 04-05-2009 It is amazing what a 60 dollar tool will do to make a tire work.He He Finally on all 4 wheels - trkbilder - 04-06-2009 Did you get this tool to do that or does it have anything to do with your work? :xyxthumbs: |
