Welch Racing Build thread - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: Welch Racing Build thread (/thread-1292.html) |
Welch Racing Build thread - cuz1 - 04-19-2009 Supposedly the tennis balls help the coil springs with hard landings and bouncing. I guess it could also work as a bump stop. We saw this on a bronco tough truck and the guy swears by them. Cheap bumpstops I guess. It looks pretty cool---good conversation piece. I would love new arms but how can I change the frame mount so It does not affect the caster or camber which ever? Welch Racing Build thread - SC74 - 04-19-2009 cuz1 Wrote:Supposedly the tennis balls help the coil springs with hard landings and bouncing. I guess it could also work as a bump stop. We saw this on a bronco tough truck and the guy swears by them. Cheap bumpstops I guess. It looks pretty cool---good conversation piece. As long as you use the same degree bushings that are in the current arms the caster should not change. Those determine what angle the arms hold onto the axle. The tennis ball trick is interesting - I bet it makes it even MORE of a PITA to change coil springs though. Welch Racing Build thread - cuz1 - 04-19-2009 What do you need from me to get the ball rolling on some new arms. Can you help me out? cw Welch Racing Build thread - cuz1 - 04-27-2009 I followed Roberts Lead on the grill for the bronco. ![]() ![]() I found this battery box in the eclosed trailer the other day--- or at least what I thought was a battery box until I opened it. WOW!!! ![]() New Moser 3rd member with 40 spline spool. ![]() Welch Racing Build thread - johnpaulgolf - 04-28-2009 Good stuff Carl ... :biggthumpup: Can I have that third member ![]() Welch Racing Build thread - cuz1 - 04-28-2009 I have plans for it. Spidertrax 9" front and rear. Welch Racing Build thread - broncomatt - 04-28-2009 Very nice carl, what gears you gona run? Welch Racing Build thread - jollygrngiant - 04-28-2009 Dang Carl, you sure lucked out. That's like finding the pot of gold w/out the leprechauns!:xyxthumbs: Welch Racing Build thread - cuz1 - 04-28-2009 broncomatt Wrote:Very nice carl, what gears you gona run? Matt, The 3rd member has 477 on it but I think I want to stick with 456--- give me some advice Welch Racing Build thread - cuz1 - 04-28-2009 jollygrngiant Wrote:Dang Carl, you sure lucked out. I have more stuff that would just blow your mind. How about a new Keith Black (hemi) aluminum block, crank and pistons. Everything you need to build a top fuel motor. I have the heads and all the head stuff. 2 Blowers, dual MSD distributors. Too much to list. Bad thing is I do not know what to do with this stuff. I guess sell it. |
