hand throttle - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: hand throttle (/thread-228.html) |
hand throttle - snipes243 - 09-24-2008 744x4 Wrote:Here are a few shots of the stock hand throttle for the EB.It mounts under the gas pedal and actually moves the pedal insted of using a carb linkage. So If you press the gas pedal will it move the hand throttle? hand throttle - 744x4 - 09-30-2008 No the throttle bracket only pulles it to the back of the pedal.It could act like a cruise control except the pull on the back of the pedal isnt that great as it only moves a little.You would need a longer pivot point. |
