the 77's upgrades - jollygrngiant - 03-15-2011 Sounds really good Chuck! Thanks for the invite the other day. Sorry I couldn't get there in time. the 77's upgrades - firefighter2134 - 03-15-2011 thats awesome. the 77's upgrades - blazinchuck - 03-18-2011 well...its running! but, running like chit!!!! ive got codes...alternator is not being turned on via rjm harness. starts up great, sounds good for a minute...then starts surging so bad it almost shuts off the 77's upgrades - broncosbybart - 03-18-2011 that sucks. any idea as to why it isn't running right?? looks like you've been busy ![]() the 77's upgrades - firefighter2134 - 03-19-2011 that doesnt make sense. you used the same harness outta fbg right? the 77's upgrades - chuzie - 03-19-2011 Sent you a long email. Get back with me; will do what I can from here. the 77's upgrades - blazinchuck - 03-21-2011 aight, i swapped a couple relays and got this thing charging and running. however, yesterday...went to go out in the bronco...and it wont take any throttle past 1500rpm. just bogs! dont know where to look now very tired of this crap the 77's upgrades - chuzie - 03-21-2011 My first thought would be fuel. Make sure your return line is unrestricted back to the tank. Make sure there is not a negative pressure in the tank. Try pulling off the gas cap and see what happens. What are you using for a fuel pump? Same injectors as before? If the low end loping was fixed with the alternator I guess we can eliminate vacuum lines as the culprit. Run a compression check. the 77's upgrades - chuzie - 03-21-2011 Here is my troubleshooting tree.... Poor High Speed Operation Low fuel pump volume Faulty pump or restricted fuel lines or filters Poor MAP sensor signal Test MAP sensor, vacuum hose and wiring Poor Oxygen sensor signal Test for shorted or open sensor or circuit Open coolant temperature Test sensor and sensor circuit wiring Faulty ignition operation Check wires for cracks or poor connections, test secondary voltage with oscilloscope Contaminated fuel Test fuel for water or alcohol Intermittent ECM ground Test ECM ground connection for resistance Restricted air cleaner Replace air cleaner Restricted exhaust system Test for exhaust manifold back pressure Poor MAF sensor signal Check leakage between sensor and manifold Poor VSS signal If tester for ALCL hook-up is available check that VSS reading matches speedometer Have you run another self test on the EEC? the 77's upgrades - blazinchuck - 03-21-2011 ok...KOER(12,21,94,44,33) KOEO(81,82,85,84) l swapped out the MAF and fuel pump relays with new replays. i cant slowly bring engine up in rpms...but can not stab the throttle |
