File Line Function
/printthread.php 287 eval
OPTIMA - Printable Version
+--- Thread: OPTIMA (/thread-495.html)
Pages: 1 2 3
OPTIMA - johnpaulgolf - 04-01-2008
jollygrngiant Wrote:John, glad to see you're getting a new one. I've had red top's in the past and never any problems. Did the acid-gel mess up your bronco badly?
Brian
It really has nothing to do with the battery I thought it did but it was a bad voltage reg. I got a replacement battery coming so...
Then the guys at alterstart are great new alt. coming...
The acid-gel did discolor the hood badly in a spot about the size of a football...a little bit on the inside of the fender...a little bit on my radiator...everything cleaned up pretty good except for the hood...but nothing that the high temp red rattle can can't fix
:xyxthumbs:
OPTIMA - blazinchuck - 04-01-2008
I think it might be time we all consider a battery discount...real close to the driver!!!
OPTIMA - chuzie - 04-01-2008
You have all the luck!!!
