Need full width info. - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Need full width info. (/thread-934.html) |
Need full width info. - blazinchuck - 08-12-2008 broncomania Wrote:76 do have disc brakes.maybe not all of them but the ones ive stripped have had disc. 76/77 both are weld on c wedges. hp44 thanks..good to know:xyxthumbs: Need full width info. - Traveler - 08-13-2008 So does the '78 and '79 F150's have cast wedges like the broncos? Need full width info. - Ogeechee 4x4 - 08-13-2008 yes Need full width info. - Traveler - 08-21-2008 Did I ask this already, How hard is it to 4 link an axle with Cast wedges? Would the wedges really be in the way? Or is there a fear a weakening it with the welding done to the tube? Need full width info. - broncomania - 08-22-2008 Traveler Wrote:Did I ask this already, How hard is it to 4 link an axle with Cast wedges?4 linking with cast wedges should not be an issue. welding to the axle will be fine. Need full width info. - Traveler - 09-03-2008 How would this work for a donor? I know it will have drum brakes, but if it really has lockers that could be a steal. He is already down from $1,200. I would assume it has power steering, is it the same box as the later trucks, so I can use it on my EB with the 2wd, worm gear change? A bargin? Thanks Need full width info. - broncomania - 09-03-2008 bucketobolts on here has axle housings for sale that are eb ready and priced cheap. and ive got the shafts,carriers,gears,brakes , etc. etc.(2 complete axles ) for $350.00 Need full width info. - Traveler - 09-04-2008 What are lockers worth? Maybe I should look. He said it has 4.10 ratios and detroit lockers in the front and read. That is what really caught my attention. Sell the snow plow off of it for $500 and it could be a pretty cheap conversion. That is a good price, but I am not sure when I would get a chance to get those parts from NC to Iowa. |
