Project "Big Country" - Front Bumper Fab - chuzie - 09-17-2012 Make sure the size limits have not changed. Maybe try uploading to photobucket or other host. Project "Big Country" - Front Bumper Fab - SC74 - 09-17-2012 I posted in the new forum thread, but it is a jpg and reduced to 640x480 and 56 kb which is less than the limits posted. If all else fails I'll go through photobucket. Project "Big Country" - Front Bumper Fab - SC74 - 09-17-2012 OK, I'm posting the pics via photobucket now. Here are the ram pics... ![]() ![]() ![]() Project "Big Country" - Front Bumper Fab - SC74 - 09-17-2012 Here is a bump stop I made for the driver side. The pass side is on top of the trac bar riser. I used existing holes on the inside of the frame and drilled/tapped two holes on the outside of the frame. ![]() Project "Big Country" - Front Bumper Fab - SC74 - 09-17-2012 I mounted a toolbox in the bed between the seats and fuel cell. Eventually I'll get a taller and much narrower fuel cell that won't take up so much space. ![]() Project "Big Country" - Front Bumper Fab - chuzie - 09-17-2012 Looks great. So I am guessing your drag link connects at the knuckle and not at the tie rod? This would explain how you have some much room on the tie rod to mount the ram where you did but I didn't see a picture that made it completely clear. Project "Big Country" - Front Bumper Fab - SC74 - 09-17-2012 Here are a few pics of me using a firewood pile for a ramp to measure for the bump stops. ![]() ![]() Project "Big Country" - Front Bumper Fab - SC74 - 09-17-2012 chuzie Wrote:Looks great. So I am guessing your drag link connects at the knuckle and not at the tie rod? This would explain how you have some much room on the tie rod to mount the ram where you did but I didn't see a picture that made it completely clear. Yes, my drag link goes all the way to the top of the high steer arm which does allow much more space. Project "Big Country" - Front Bumper Fab - SC74 - 09-17-2012 I put a WH family cage bikini top on it. I had a local sew shop add some 2" velcro straps to the length of it to add some extra support. She sewed 4 straps on each side. ![]() ![]() Project "Big Country" - Front Bumper Fab - snipes243 - 09-18-2012 looks great there man |
