Body is off! - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: Body is off! (/thread-2606.html) |
Body is off! - scbronco - 03-01-2011 well, all the panels are hung, and i think i got a good rough sand on the tub. ready to spray the first coat of primer this weekend hopefully. also, i got the engine off the frame, and almost ready for the final coat of rust bullet on the frame. Big thanks to crawdad for coming out and helping me get the motor off, and the body in the garage. also, he put his metal skills to work and helped line up and burn in my rear quarters. School is demanding too much time right now, and slowing down progress, but i only have a month left to go on that. unfortuantely the heat of summer is right around the corner, and thats gonna bring things to a snails pace... still motivated, just gotta fabricate some time... ![]() Body is off! - Crawdad - 03-01-2011 You need to fabricate a way to bring that monster boat to my lakehouse this summer!!!! Body is off! - scbronco - 03-01-2011 also, i am taking pics, but im trying to wait until the whole truck is finished to post up pics of the paint and body work... once i get into the chassis the pics will start coming again... I may get too excited when the paint is done though, and have topost up a pic or two... ive already spied the green, and it is super bad @$$... i might no tbe able to wait... Body is off! - blazinchuck - 03-02-2011 glad to hear things are getting done. it is nice having a bud come by to lend a hand!! good work guys!! Body is off! - scbronco - 03-05-2011 laid the first coat of primer down. im not real enthused about how its spraying. spray is real thin, takes several passes just to start to cover. maybe thats how its supposed to be, but i thought it would coat a little thicker in a pass, like one pass to cover, another to recoat. maybe not. regardless, i should be done spraying by tomorrow, and have it sanded smooth. hopefully be ready to test spray the paint on a test peice on sunday... now to finish my homework... Body is off! - broncosbybart - 03-05-2011 you did stir the primer really well, right? primer has a habit of settling really badly. you might use a little less thinnner to try and thicken it up a bit. i've had some primers spray thin as well. kinda sucks because it takes that much longer- and i hate body work... looking forward to seeing some pics!!! Body is off! - scbronco - 03-06-2011 i got it dialed in today, i had to make some gun adjustments, as well as mixing adjustments. went down super smooth and covered in one pass. im gonna do a light sand to smooth the whole thing back out, and then lay down 2 more good coats with a light sand in between coats. then some color... 8) Body is off! - High Pressure - 03-06-2011 NGABronco Wrote:Hey Nick, that thing is looking good!! Great job on the bracing!!! Now get back to work!!! Yea... what NGA said....:beer: Body is off! - scbronco - 03-06-2011 1st coat of primer... ![]() Body is off! - NGABronco - 05-06-2011 Hey nick, the axle is supposed to be black!!!!! |
