Homebuilt SxS - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: Homebuilt SxS (/thread-3117.html) |
Homebuilt SxS - snipes243 - 08-12-2014 sweet looking Homebuilt SxS - Wickedlester - 08-12-2014 looks way for fun than a sxs to me... Homebuilt SxS - ParadisePWoffrD - 08-12-2014 thanks guys. I am also in the process of going back to gasoline, and trying to work a rear seat into it. Will add some tube to the back to protect the rear passengers and hold the fuel cell. Homebuilt SxS - blazinchuck - 08-18-2014 609 looks badass! nice and low too on the rig Homebuilt SxS - ParadisePWoffrD - 08-19-2014 Thanks. I picked up the housing years ago for a good deal, and finally was able to use it. I do have a mint in it, even with the lp 3rd, but i think it will give me the best of both worlds with weight, ratios, and strength. I wanted the rig to get lower. In the pic its 2" above full bump. I have already raised the motor, and any lower I will be into the oil pan. I might push the front out some more if needed to get lower, but really dont want to mess with the look too much. It still should be able to fit out of a std garage at ride height. Homebuilt SxS - ParadisePWoffrD - 08-25-2014 Got the rear 4link in place. Still need to do some work to brace the truss and strengthen up the rear axle. Also had a friend cut out a header flange for me. Going to start mocking up and working on the turbo setup once this thing is rolling again. Homebuilt SxS - ParadisePWoffrD - 09-15-2014 Messed around with it for a little. Got the shocks mounted up & orbital placed. It is currently sitting on blocks. Ride height will be a few inches higher. Getting ready to start on the boatsides next. Will try to roll it out soon and get some pics in the sunshine. Homebuilt SxS - ParadisePWoffrD - 12-15-2014 Its been a while, but have a small update. Rolled it out to get some pics. Put in some door bars, which will become the top of a boatside, and also have the seats mounted to them. Currently sitting pretty close to ride height. Would like it lower, but its not too bad. Homebuilt SxS - broncosbybart - 12-16-2014 I think you need to change the title on your thread now. ![]() Keep up the good work! Homebuilt SxS - ParadisePWoffrD - 12-16-2014 haha yeah. Since the removed parts havent sold, it may be back in a different form (kid crawler). |
