Ms Piggy. Black and Blue! - jac77 - 03-05-2014 Nice work must be soooooo nice to have a lift! Looking good : ) Ms Piggy. Black and Blue! - broncosbybart - 03-05-2014 Yes, I'm very blessed with the things I have. No doubt about that. The lift is a great thing! Nick, Skips old Bronco runs/drives and is licensed but I don't drive it. It's too cold right now- well that and it is supposed to be Sharon's Bronco. ![]() Ms Piggy. Black and Blue! - broncosbybart - 03-09-2014 The engine is out! Time to gather parts from all over the premises. Stuff is here, there, and everywhere... Got a fair bit of it piled up now. Some I might use, some I might not. A partial list entails the new to me 4BTAA in the garage now. It is a 2001 year model and is the P-pump model. Who knows if that is really needed for this beast, but it can't hurt. The P-pump is supposed to be the best for fuel delivery for high performance tweaking. Heck, it might just stay very close to stock. Time will tell. As well, there is a Dodge NV-4500 trans sitting there, the Atlas 4 speed transfer case, a 14 bolt rear axle, a Detroit for the 14 bolt, a HE351 turbo (not sure if I'll use it yet or not), suspension parts, steering gear, and more. Ms Piggy. Black and Blue! - blazinchuck - 03-09-2014 i dont like you anymore lol....4bt,nv4500,atlas...yeah i dont think i like you hahaha Ms Piggy. Black and Blue! - snipes243 - 03-09-2014 I stopped liking him after I helped moved that 14 bolt of his Sent from my iPhone using Tapatalk Ms Piggy. Black and Blue! - chuzie - 03-10-2014 I never liked him from day one! Sent from my GS3 on CyanogenMod with tapatalk2 Ms Piggy. Black and Blue! - Crawdad - 03-10-2014 I like him, he's my Fred Sanford! One of my first stops when I get home! Ms Piggy. Black and Blue! - broncosbybart - 03-10-2014 Well, like me or not, the build continues! ![]() The front axle installation needed a bunch of help. The front shocks were installed wrong. The front brake hose brackets were welded to the frame. The fabbed up front spring 'lift pucks' are going away. The biggest thing is the caster is -1 degrees!!! So, here we go. Ms Piggy. Black and Blue! - broncosbybart - 03-10-2014 The front axle is out! Plans are to use the Cage/Bloody Knuckle D60 weld on brackets and remove the weld on wedges that someone installed on the axle. Judging by the welds, the wedges were not Dynatrac items. With a fair amount of cutting and grinding, the wedges are off! Got the bushings installed in the weld on brackets and did some grinding on them to get them ready to install. Ms Piggy. Black and Blue! - chuzie - 03-10-2014 Don't you have a job? Oh, i forgot this is your job. So are you paying yourself for this project? Sent from my GS3 on CyanogenMod with tapatalk2 |
