The Love shack - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: The Love shack (/thread-2107.html) |
The Love shack - Badass - 03-30-2010 thanks guys. progress has been a little slow but thats gonna change come pay day!! The Love shack - Badass - 03-31-2010 i fastened all the DP on today temporarly. checking fit etc. I pre drilled all the holes and ran 1" drywall screws in. this pre drills tha holes in the wood and when i pull it all off to seal it i can put caulking in the hole and under the screw. it all fit real well. i have to cut out for the furnace and trim one back piece but thats it. i also will eventually do the doors as marked and probably the pass thru doors. The Love shack - Badass - 03-31-2010 The Love shack - Badass - 04-03-2010 The Love shack - bone collector - 04-03-2010 all its missin is some SPINNERS LOL BLING BLING The Love shack - Badass - 04-04-2010 bone collector Wrote:all its missin is some SPINNERS LOL BLING BLINGon order......NOT. lol The Love shack - Badass - 04-05-2010 got a few things done. got slider mounted and operational and put the rest of the trim on it. i pulled out the awning to look at it and let it air out. i am missing a leg on it and one of the feet are broken. i got all the DP mounted on the drivers side. I sealed and mounted the electrical inlet flange and the phone and 2 cable hookups. i mounted the pass thru door and figured i would try my luck with running a bead around it. it came out good. I used to work with silicone a lot and was pretty good at running beads but you loose it if you dont do it. i also went ahead and sealed the top and 1st seam of the DP. came out really well im happy. i got one side of the slide done and am about to go eat then start the other side of the slide. i would like to get all the DP mounted and sealed today. the piece at the top i am missing from the other side. this is the foot of the awning. it is supposed to have a piece between the arrows thas broken The Love shack - Badass - 04-05-2010 except the corner and bottom angle, the passenger wheel well trim, furnace install and clean up the outside is about done. all the DP is on and sealed The Love shack - Mill Knob - 04-05-2010 Man you do some jam up work. Keep up the good work. The Love shack - Badass - 04-05-2010 thank you sir. i got a few hrs to tighten it up on the outside. install furnace, remove stickers from storage doors and slide frame. remount awning feet. I have to get one more sheet of DP for the front also. i need to start cleaning up and packing. im moving back to Mcbee by may 1 |
