Homebuilt SxS - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: Homebuilt SxS (/thread-3117.html) |
Homebuilt SxS - ParadisePWoffrD - 04-27-2015 Between work and having a new baby, there hasn't been much time for this thing. My buddy brought over his racecar scales and we weighed it for giggles. ![]() This was without the fuel cell, seats, and a few other misc parts. Hoping to get it lowered some more and stay under 2500 lb complete. Homebuilt SxS - snipes243 - 04-27-2015 Pretty light looks good Sent from my iPhone using Tapatalk Homebuilt SxS - ParadisePWoffrD - 01-19-2016 Have been messing with it a little lately. Cut out the 4 link front and putting a 3 link back in. Getting more uptravel and wheelbase from the swap. ![]()
Homebuilt SxS - broncosbybart - 01-19-2016 Ok, I'm confused. Are we talking about the POS in the foreground or did you fabrimicate the utv looking thing in the background. :bdent: Homebuilt SxS - ParadisePWoffrD - 01-19-2016 Haha it's the hunk of crap in the foreground. The thing in the back is an actual rzr. It's funny how bare steel rusts when you let it sit out for a yr. Sent from my SM-N920V using Tapatalk Homebuilt SxS - broncosbybart - 01-19-2016 Just pickin'.. She's not so much a SxS anymore. Keep it up! Homebuilt SxS - ParadisePWoffrD - 02-17-2016 Haven't gotten much picture worthy done, but have been working slowly on it. Cut off the rear factory frame and some tube. Will redo it later. Also moved lower rear coilover mounts to get them more vertical. On the front I tacked up the rest of the 3 link and coilover mounts. Still trying to decide on single vs. double ended ram for steering. Last night I decided to tackle the power steering pump. Putting a TC pump on the 1.6 is common, but no one makes a bracket to allow an aftermarket pump and the a/c pump. I used the factory brackets from the kick and jeep (TC pump) to get it mounted. Currently it is just tacked in place. I mocked it up and should work great. 2 brackets tacked up TC pump mounted PS pump and A/C comp brackets mounted up together Homebuilt SxS - ParadisePWoffrD - 03-02-2016 Spent some time last night putting together my low buck steering ram. Turned 2 single ended rams into 1 double. Homebuilt SxS - blazinchuck - 03-02-2016 cool, surely you took pics of that process?? Homebuilt SxS - ParadisePWoffrD - 03-02-2016 blazinchuck Wrote:cool, surely you took pics of that process??I thought about it but didn't since I wasnt 100% of the outcome. Currently, I turned 2, 2"x10"s into 1, 2"x7.625" ram. I will be taking it apart to modify it some to get the full 8" of travel. I also know a few ways to get it to 10" travel, but I don't need that right now, some idk if I'm gonna spend the $$ |
