Chuzie's monster transformation - scbronco - 10-25-2011 chuzie Wrote:Thanks! At this point, he has put more miles on my new tires than I have. The tires / rims look great but let's see if they perform in a couple weeks. Pics or youre lyin'! i question the aesthetics of the new tires based on a lack of evidence!!! PICS!!! Chuzie's monster transformation - chuzie - 10-25-2011 I am in Florida right now and Chuck has my rig in Charleston. Chuzie's monster transformation - blazinchuck - 10-25-2011 tell ya what, in the next day or so...im installing twin sticks in the yellow heep...then ill post up some flex shots!!! not like that ole flexing chuzie does hehe Chuzie's monster transformation - chuzie - 10-25-2011 Oooooo! I like flex shots! Bring it on. Flex that beotch till the driveshafts fall apart! Chuzie's monster transformation - blazinchuck - 10-26-2011 as promised... Chuzie's monster transformation - chuzie - 10-26-2011 Thanks for the pics Chuck. looks like I have some trimming to do on the front fenders to accomodate my new tires. When we first installed this system I was running 35's that were worn down to 33's. Also seems you are correct on the rear shocks limiting up travel. I just assumed the coils were automatically the limiting factor but guess not. I called Duff's and they are aware of the issue and said they had to make a choice to either limit compression or extension because have both was not possible for some reason. They suggested I incorporate bump stops. Chuzie's monster transformation - NateMob - 10-26-2011 I cant tell in the photos but if you lose the outboard shocks and just kept the inboards would you get more travel? Chuzie's monster transformation - chuzie - 10-26-2011 I wasn't there to get a good look but that thing is unstable enough as it is with 8 shocks. Can't imagine losing a couple even if I did make them quick disconnect for trail use. I think there must be a better solution rather than a band-aid. Chuzie's monster transformation - blazinchuck - 10-26-2011 there was only a 1/4" diff between the outboard and inboard...so that wouldnt really work at all. good thought tho Chuzie's monster transformation - BucknEB - 10-27-2011 Dayum!!!! Those flex shots look sweeet! :rubeyes: |
