ECORS Class A race rig build - broncosbybart - 02-14-2011 No prob on the engine stand! Ruff Stuff has them. These are the 1-1/4" heims. They fit pretty well. I did have to do some minor grinding on the ends of the misalignment spacers to make them fit between the mounting brackets, but that was easy. ECORS Class A race rig build - bucketobolts - 02-15-2011 Here is an update on the C4 that is holding up the drivetrain. I'm starting out with all Alto Red racing clutches, Kolene coated steels, and a Kevlar lined intermediate band. The direct or high gear drum has been trued and refinished. Then I drilled relief vents in the clutch area of the drum. This will help release the band and apply the clutches quicker for a better 2-3 shift. I added 1 clutch fiber and steel for a total of 5 and set the clutch clearance to a nice tight .025". The forward clutches have also been clearanced to .025" with 5 clutches and steels. I don't think this application will warrant welding the peanut slots in the face of the hub, which is usually done when lots of cubic inches are combined with big boost or lots of NOS. I have also finished the stator for the pump. The plug is drilled out of the housing, followed by removing the 2 check balls and spring. I tapped the hole to 1/8th pipe and installed a brass plug. The plug is not install too deep where it restricts the outlet and then filed to shape. ECORS Class A race rig build - broncosbybart - 02-15-2011 HOT DOG!! Looks like you have been busy. You are the MAN!!! I don't know what a lot of that stuff does, but kevlar can't be a bad thing, right??? Clay did suggest we run NOS and paint it like a fire extinguisher bottle to disguise it A HUGE thank you for all the help!!! ECORS Class A race rig build - blazinchuck - 02-15-2011 dayum...Aaron, you gonna build some tough c4's for members?? ECORS Class A race rig build - bucketobolts - 02-16-2011 blazinchuck Wrote:dayum...Aaron, you gonna build some tough c4's for members?? Thought you fellas were die hard NP435 men? ECORS Class A race rig build - bucketobolts - 02-16-2011 The BTE racing pan showed up this afternoon. Its a heavy piece that adds a couple of quarts of capacity and helps strengthen the case. The pan comes with all the hardware, deep sump filter, and reusable gasket. The pan is also dimpled marking where you can drill and tap for temp gauges or to route wiring for a transbrake. ECORS Class A race rig build - snipes243 - 02-16-2011 Looks Sweet cant wait to get in The bronco ECORS Class A race rig build - cuz1 - 02-16-2011 Charles, I cant tell you how impressed I am with the build. Excellent work. ECORS Class A race rig build - broncosbybart - 02-16-2011 Thanks all! Gonna have to put a ton of CB4x4 stickers on it fo sho! make sure all those Jeep folks know it isn't a Jeep that just ran them over!!! That trans is gonna be off the chain!!! looks like i will need to fab up a HUGE push bar on the front of this thing ECORS Class A race rig build - snipes243 - 02-17-2011 broncosbybart Wrote:Thanks all! Gonna have to put a ton of CB4x4 stickers on it fo sho! make sure all those Jeep folks know it isn't a Jeep that just ran them over!!! Now we just are gonna need someone to keep there foot in the gasupergrin: |
