Homebuilt SxS - Printable Version
+---- Thread: Homebuilt SxS (/thread-3117.html)
Pages: 1 2 3 4 5 6 7 8 9 10
Homebuilt SxS - broncosbybart - 03-03-2016
I'd like to see how you dun it.
Pretty slick!!
Homebuilt SxS - ParadisePWoffrD - 03-09-2016
ParadisePWoffrD Wrote:Spent some time last night putting together my low buck steering ram. Turned 2 single ended rams into 1 double.
[Image: standalone?embedded=1]
Some more about how I did it.
I pulled the rams apart. In these pics you can see the pieces:
1.125" Shaft w/ clevis, end cap, piston, and 3/4-16" nut.
[Image: 10eb809d1e4a1cb6cb8aeb924002a9aa.jpg]
Rods 7/16"
[Image: 1a2dc281dd2b55bf888ec8bec5e10a5a.jpg]
Body 1.99" ID, 2.375" OD, 12" long.
[Image: 39169ac0c5568fd136448652054be71c.jpg]
I trimmed the threads on each shaft to 7/16" long and threaded the 2 shafts opposing into a 7/8" wide nut.
[Image: 2944e4dd8c184381578b1bbf77dbee0a.jpg]
I then stuffed it back into the body and reinstalled the end caps, clevis, and tie-rods.
Current travel is 8.125". If I minimize the spacing between the pistons or use a longer tube, I should be able to get 10" of travel. I don't need that unless I upgrade the shafts.
Homebuilt SxS - ParadisePWoffrD - 03-17-2016
Spent some time trying to package the panhard. Originally had it in front of the axle in a traditional location, but couldn't fit the steering there also. Decided to move it to the rear of the axle. Everything is very tight.
Homebuilt SxS - snipes243 - 03-17-2016
Looks like a tight fit
Homebuilt SxS - chuzie - 03-17-2016
snipes243 Wrote:Looks like a tight fit
OMG! That's what she said!!!!!!!
chuzie Wrote:OMG! That's what she said!!!!!!!
Very true
Homebuilt SxS - ParadisePWoffrD - 06-02-2016
Haven't had much time lately, but I got most of the welding done on the axle.
Ended up having to ditch the double ended ram for now, as it didn't fit like I wanted. Ill use it for something else. Also, that was as high as I could get the tierod and clear the frame at full bump. It will be .250 wall, so it should be fine. Ford arms are higher than Chevy's.
Homebuilt SxS - broncosbybart - 06-02-2016
Looks good. Sucks that you couldn't get the double-ended ram to fit. You going to have it ready for the SHOP ride, or are you taking something else out there?
Homebuilt SxS - snipes243 - 06-02-2016
Suck on the double ended ram. Can't wait to see this baby done.
Homebuilt SxS - ParadisePWoffrD - 06-03-2016
broncosbybart Wrote:Looks good. Sucks that you couldn't get the double-ended ram to fit. You going to have it ready for the SHOP ride, or are you taking something else out there?
I wont have it ready for the SHOP ride this month. My goal was Dixie Run but I found out I cant make that. Im currently in the process of closing on a house, so moving and house projects will consume my time for the next few months. It's taken long enough that I want to get it done, but am also not going to rush it.
snipes243 Wrote:Suck on the double ended ram. Can't wait to see this baby done.
Thanks me too. It's been too long for me out of the driver's seat.
