Chuzie's monster transformation - scbronco - 10-27-2011 sweeeeeeeet... Chuzie's monster transformation - NateMob - 10-27-2011 chuzie Wrote:I wasn't there to get a good look but that thing is unstable enough as it is with 8 shocks. Can't imagine losing a couple even if I did make them quick disconnect for trail use. I think there must be a better solution rather than a band-aid. What about an Anti-Rock Sway bar? From what i understand they make the suspension work better for on road as well as off. ![]() Nate Chuzie's monster transformation - chuzie - 10-27-2011 Chuck and I intend to fab do a sway bar setup. We have the parts but hae been so busy lately, it is at the bottom of our list. I just have to take it easy on the road. Chuzie's monster transformation - chuzie - 11-04-2011 Add these to the complete list... *** Ammeter gauge *** NOT NEEDED *** *** Electrical oil press gauge *** COMPLETE *** *** Electrical water temp gauge *** COMPLETE *** *** Hood bumpers *** COMPLETE *** *** Mechanical oil press gauge *** NOT NEEDED *** *** Reduction gear starter *** COMPLETE *** *** Repair + paint beadlocks *** COMPLETE *** *** Twin stick *** COMPLETE *** *** Volt meter gauge *** COMPLETE *** 52 down, 78 to go! I hope to get her on an RTI this weekend and finally submit the numbers I promised over a year ago. ![]() Chuzie's monster transformation - blazinchuck - 11-08-2011 chuzie Wrote:I hope to get her on an RTI this weekend and finally submit the numbers I promised over a year ago. :thefinger:F A I L :thefinger::hysterical: Chuzie's monster transformation - chuzie - 11-08-2011 4 more doneski! *** Relocate O2 sensors *** COMPLETE *** *** Tranny cooling fan operation indicator *** COMPLETE *** *** Tranny temp unit *** COMPLETE *** *** Verify engine component castings *** COMPLETE *** Here is my new gauge cluster. I removed the radio area and relocated the cigar lighter. Chuck fabricated this awesome stainless cover plate to house everything. I have a switch to override my fans, a spare switch that will likely be for onboard air in the future, and two feedback lights. The green one tells me the trans cooler fan in operating and the red one tells me when it is not operating. I know it seems a bit overkill, but I have had a couple of instances where the fan has failed and since I am not running trans cooling through the radiator anymore, I have no redundancy in the system and cannot afford to cook my trans. ![]() Chuzie's monster transformation - blazinchuck - 11-08-2011 that does look coooool!!! Chuzie's monster transformation - broncosbybart - 11-08-2011 I like it! But, I gotta ask. Why is it reading 9V with the key on??? Chuzie's monster transformation - SC74 - 11-08-2011 It looks good! Rather be safe than sorry with overkill gauges, switches, and lights. Chuzie's monster transformation - josephitguy - 11-08-2011 broncosbybart Wrote:I like it! But, I gotta ask. Why is it reading 9V with the key on??? Angle of Pic I would guess. Looks like the gauges are angled toward the driver but the camera is straight on. Chuzie, no diff temp? No power steering temp? You need more gauges! :hysterical: How long is your "pre-crawl" list? |
