Homebuilt SxS - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: Homebuilt SxS (/thread-3117.html) |
Homebuilt SxS - ParadisePWoffrD - 07-20-2016 Got the parts welded up and front axle back under it. ![]() ![]() Now on to the rear. Homebuilt SxS - snipes243 - 07-21-2016 ParadisePWoffrD Wrote:Got the parts welded up and front axle back under it. Getting closer there Ben Homebuilt SxS - ParadisePWoffrD - 07-21-2016 snipes243 Wrote:Getting closer there BenThanks. The rear shouldn't take as long for the suspension. I really need to put it on a lift to finish weld inside the frame and build the new tcase crossmember. I'm in the process of buying a house, so hopefully I can save up and install one not long after. Homebuilt SxS - ParadisePWoffrD - 08-24-2016 Picked up a set of air shocks for this thing. Should help lighten it up and get on the trail quicker. Still have the coilovers if I need the performance. ![]() Also started on the rear. Welded up the upper control arms. ![]() Put it at bump and started mounting air shocks.
Homebuilt SxS - chuzie - 08-24-2016 One day I think I may actually see this thing on the trail. Any goal for a date or time line? Homebuilt SxS - ParadisePWoffrD - 08-25-2016 chuzie Wrote:One day I think I may actually see this thing on the trail. Any goal for a date or time line? Haha. That is a running joke around here with my buddies. I have had a number of rigs that get torn down for rebuild and then parted. I am determined that this one will make it back on the trail, even if not 100% what i started for it to be. This will also be the last one (for now) that i cut up from factory frame, vs just building a tube chassis. I had a timeline of this fall. Many things in life have changed since then. I recently bought a house, which has all the right parts, but it needs quite a bit of work around the property so that will derail this quite a bit. It does have a moderately sized shop, so hopeuflly i can get that cleaned up and moved into, and it will help with the build also. Homebuilt SxS - ParadisePWoffrD - 11-22-2016 Haven't worked on it much. Been busy working on the house and new shop. Finished up the rear shock mounts and rolled it outside, to move it to the house. ![]() ![]()
Homebuilt SxS - blazinchuck - 11-29-2016 looking pretty bade-A Homebuilt SxS - broncosbybart - 11-30-2016 I think you need to change the thread title
Homebuilt SxS - ParadisePWoffrD - 12-01-2016 broncosbybart Wrote:I think you need to change the thread title I did on the first post, but it didnt in the thread list. |
