Need full width info.
blazinchuck Wrote:if I'm not mistaken, if it's a D44 8 lug, just get new hub/rotor for a D44 5 lug. They should be interchangeable.
I've got the parts to swap from 5 lug to 8 from a '78/9 F250. The knuckles are the same, but spindle, caliper bracket, caliper, hub, rotor are different...
he needs caliper brackets,hubs,rotors,calipers,spindle,stub shaft.
edit:if i remember correctly the stub shaft is just a hair longer.
broncomania Wrote:edit:if i remember correctly the stub shaft is just a hair longer.
Is it? 79f150 & I looked into that and we couldn't find a straight answer...
If we bought a F250 D44 we would just stay with the 8 bolt stuff, rims are cheap and easy.
So what years F150 had the welded on Wedges?
1977? I found an excellent donor for $500
I could use tires, wheels, body parts, interior it all looks good yet.
Or a '76? One here with not as many good parts for $400.
Or is that still too new?
Thanks again guys.
the 76 will have drums and a 77 will have disc. the 78 and up will have cast wedges. I think the 77 will have the thickest axle tubes also..mine are 1/2 wall thickness. 76-77 weld on wedges,HTH,Chuck
johnpaulgolf Wrote:I would'nt know nothing about no fullwidths...:angry:
:angry: :finger: :puke:
johnpaulgolf Wrote::angry: :finger: :puke:
would you quit your crying:hysterical::thefinger:
blazinchuck Wrote:the 76 will have drums and a 77 will have disc. the 78 and up will have cast wedges. I think the 77 will have the thickest axle tubes also..mine are 1/2 wall thickness. 76-77 weld on wedges,HTH,Chuck
76 do have disc brakes.maybe not all of them but the ones ive stripped have had disc. 76/77 both are weld on c wedges. hp44
67" wms to wms thick axle tube.
note: the only reason for the thicker axle tube was because the c wedges were being welded on. the heat from being welded required thicker steel tube.
blazinchuck Wrote:would you quit your crying:hysterical::thefinger:
:hysterical::hysterical:
Ogeechee 4x4 Wrote:Is it? 79f150 & I looked into that and we couldn't find a straight answer...
as far as i know, they are.
  Timed vs full??? Crawdad 11 3,494 03-02-2011, 10:52 PM
  Headers - Shorty or Full Length 2000F150SAS 3 1,910 01-27-2010, 04:08 PM
Last Post: BigBird13
  I need to know the Radius Arm width. 2000F150SAS 0 900 06-17-2009, 10:00 AM
Last Post: 2000F150SAS
  doors on the full size supertoyota88 4 1,304 05-05-2009, 01:08 AM
  full size buckedupbronc 8 3,983 11-04-2007, 09:14 PM
