#71
it's in the same place it was the 1st time I did it a few years ago. I could have reused the old system, but it was really restrictive. No one could bend the 3-90% bends in a row, that I needed to get over the frame in the rear. I hope it doesnt cause any problems.
happy to hear its up and running again. I'll have to come out and take a look and listen!
Brian
been working on the bronco all day. Got the front axle in, track bar done,gears installed. I still need to install the knuckles and ream them for the TRO, then install all the front hub,rotor,and brakes. Also install the power steering pump, pulleys,belts, shroud. Wont be long now guys!Chuck
You're on the last stretch now Chuck... can't wait to see pics when it's done. Good Luck.
Well, I gave up last night. I was going to try and finish it, but got too tired. I still need to install all the front and rear brakes. I got all the holes reamed for the TRO, just need to weld all the bungs in. Hopefully my steering box will show up today along with the rear calliper bracket. Also, the rear drive shaft needs to be about 2" longer now. I think I gonna pass on the door inserts and half doors...I'll be doorless again @ URE. :lol: And I still need to trim the front fender for the bigger tires,Chuck
I'll post pics when it on all 4's
here's the dealio...I got the steering done,front hub/rotors,brakes. I had to ditch the hydro!!!! :evil: they tap the top of my box, and now I cant fit a belt on or the hoses for the ram. The pump sits right on top of the hoses. I will need to order those brackets that drop the box down 1" and move it forward about 3/4".
I'm taking a break right now for grub, then going back to convert the rear to disc. I had the rear drive shaft lengthened-just gotta install that. Then double check every dang bolt,nut, and install all the cotter pins!!! Should be driving out tonight.
Later........................Chuck
very cool. can you finish mine now? it only needs more money! :lol:
bryan
she ain't coming out tonight boys! I list the crap in the disc brake help section,Chuck
I'm tooooo tired to talk right now, but pics say alot more!
BRIAN,THANK YOU FOR ALL YOUR HELP TODAY!WOULDN'T HAVE HAPPENED WITH OUT YA!
[Image: 4x4pics1396.jpg]
[Image: 4x4pics1392.jpg]
[Image: 4x4pics1391.jpg]
[Image: 4x4pics1384.jpg]
[Image: 4x4pics1383.jpg]
[Image: 4x4pics1382.jpg]
[Image: 4x4pics1381.jpg]
damn right. lookin good chuck.
  Bertolini's '71 build blazinchuck 4 1,679 09-13-2015, 08:49 PM
